3g dropped and dead my customer's iphone 3g was dropped and dead but when i connect to charger it power on with apple logo then turn off its self again... please help! |
should fix your problem. best wishes |
i have changed and check the battery already and i'm sure the battery connected to the logic board by using multimeter to measure it... what else can i do? |
i noted that nth is heating... so i decide to change power ic but no luck... the iphone now can't turn on even i connect to charger... please help |
have no voltage or more than needed,they must have 1.35V,1.8V,1.2V. |
Before replacing the power ic, why dont you just take the board and put it in other working device? :-) I don't fix boards, so this is what I do in first place :) |
In this way check all coils.Good Luck. |
Also check big green fuse for continuity near of antenna conn,if open make jumper. |
you have to change PMIC 100% it's a very known problem, i repaired many of them. do you have MSN / ICQ / Yahoo? I can tell you some measure points to confirm this problem. BR Matthias |
