Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 10-08-2011, 05:31   #1 (permalink)
Member: 1296569
Thanks Meter: 3
3g dropped and dead
my customer's iphone 3g was dropped and dead but when i connect to charger it power on with apple logo then turn off its self again... please help!
Old 10-08-2011, 05:38   #2 (permalink)
Member: 534777
Thanks Meter: 214
Bro, it's a battery connector issue. open it and check/adjust the battery terminals, inspect to see if all is ok with the terminals and resit all the connectors.
should fix your problem.
best wishes
Old 10-08-2011, 06:45   #3 (permalink)
Member: 1296569
Thanks Meter: 3
best wishes
thank friend
i have changed and check the battery already and i'm sure the battery connected to the logic board by using multimeter to measure it... what else can i do?
Old 10-08-2011, 09:16   #4 (permalink)
Wites OM Tesla's Avatar
Member: 1017374
Thanks Meter: 2,594
thank friend
Check entire board with charger connected maybe some component is heating.
Old 10-08-2011, 10:36   #5 (permalink)
Member: 1296569
Thanks Meter: 3
thank i'll check and reply result
Old 10-26-2011, 09:02   #6 (permalink)
Member: 1296569
Thanks Meter: 3
i noted that nth is heating... so i decide to change power ic but no luck... the iphone now can't turn on even i connect to charger... please help
Old 10-26-2011, 09:20   #7 (permalink)
Member: 1017374
Thanks Meter: 2,594
Now check all coils if they generate voltages,mark in a photo & post which
have no voltage or more than needed,they must have 1.35V,1.8V,1.2V.
The Following User Says Thank You to Wites OM Tesla For This Useful Post:
Old 10-26-2011, 10:08   #8 (permalink)
Member: 1647959
Thanks Meter: 13
Before replacing the power ic, why dont you just take the board and put it in other working device? :-)
I don't fix boards, so this is what I do in first place
Old 10-27-2011, 16:24   #9 (permalink)
Member: 1296569
Thanks Meter: 3
Can u tell me how to check it?
Old 10-27-2011, 16:26   #10 (permalink)
Member: 1296569
Thanks Meter: 3
Thx friend....I try this already but it doesn't work
Old 10-27-2011, 16:37   #11 (permalink)
Member: 1017374
Thanks Meter: 2,594
Power phone without LCD,with multimeter check put black probe to GND red to Coil check both solder pads of Coil,but be careful do not short coil to gnd.
In this way check all coils.Good Luck.
Old 10-28-2011, 04:48   #12 (permalink)
Member: 842633
i check already but i could find only 3.7V... what wrong with it?
Old 10-28-2011, 05:33   #13 (permalink)
Member: 1296569
Thanks Meter: 3
Old 10-28-2011, 12:17   #14 (permalink)
Member: 1017374
Thanks Meter: 2,594
Go here and look what must be at coils http://forum.gsmhosting.com/vbb/f631...ml#post7838270
Also check big green fuse for continuity near of antenna conn,if open make jumper.
Old 10-28-2011, 13:45   #15 (permalink)
Member: 1012778
Thanks Meter: 245
you have to change PMIC 100% it's a very known problem, i repaired many of them. do you have MSN / ICQ / Yahoo? I can tell you some measure points to confirm this problem.
BR Matthias
The Following User Says Thank You to kostelectronics For This Useful Post:
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 20:09
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-15-2011 13:08
wt603 and .pkd ARt Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-13-1999 19:18
Page generated in 0.27363 seconds with 9 queries
