07-15-2017, 11:58 | #1 (permalink) |
Junior Member Join Date: Sep 2013
Member: 2030266 Status: Offline Thanks Meter: 0 | Back light IC iPhone 5s to 6 and home button problem Any try this ? Backlight ic ( u23) with iPhone 5s will be works in iPhone 6 ? 2) I have a problem with iphon 5s. When the home button is connected the battery is very quickly discharged. I test same home in other logic board and everything works perfect. A change flex cable and other home buttons but still battery draining. |
07-18-2017, 06:13 | #2 (permalink) |
Freak Poster Join Date: Feb 2006
Member: 232487 Status: Offline Thanks Meter: 53 | 1- Yes, it is same 2- Check home button lines with using ZXW or Pads. I think u have a short. Use multimeter and find short on home button lines. If u have short more than one, connect 2.5v to line. It will get hot. U can use freeze sprey. It will be easy. If u don't have find it with hand and try. And also u can use solid flux. When u give 2.5v it be liqiud |
