Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 10-14-2014, 06:59   #91 (permalink)
Member: 1260512
Sonork: 100.1605447
Thanks Meter: 461
Ipad 3 A1430 after removed R1204 now in DFU but can't restore firmware
what problem and how can i solved it?
pls help me all user .
Old 10-14-2014, 13:18   #92 (permalink)
Member: 732994
Thanks Meter: 81
Wink
restore as wifi model
The Following 2 Users Say Thank You to MrDevil For This Useful Post:
Old 10-14-2014, 16:14   #93 (permalink)
ton1x's Avatar
Member: 258858
Thanks Meter: 96
Originally Posted by n.nha View Post
Ipad mini = model A1454 , A1455
Ipad mini2 retina = model A1490 , A1491
Check model ipad Identifying iPad models
Ofcourse my Ipad mini2 retina = model A1490.
I removed r1204 and 1205, i connect it to itunes but itunes detected my ipad mini2 retina as iphone.
Please help me to fix it..
Sent from my iPhone using Tapatalk
Old 10-14-2014, 18:36   #94 (permalink)
Member: 2240910
can this work on any ipad with wifi only? sorry im little confuse
Old 10-14-2014, 19:09   #95 (permalink)
danisajee's Avatar
Member: 755480
Sonork: 100.1609798
Thanks Meter: 233
It's not working for iPad wifi models it's only working gsm model iPads ... Bcz gsm model iPad iCloud register with imei in apple data base when you remove resistor from your iPad gsm it's convert to iPad wifi model.. After convert it it's activate with serial no.. so iCloud gone .. But iPad wifi models register at apple server with only serial no.. Serial no with iCloud activation already register in apple data base so wifi models cannot be bypass this method ...
Old 10-15-2014, 05:18   #96 (permalink)
Member: 1260512
Sonork: 100.1605447
Thanks Meter: 461
Pls give me solution for Ipad 2 A1395
Old 10-15-2014, 07:39   #97 (permalink)
CONCORDIA GSM's Avatar
Member: 209722
Thanks Meter: 818
Originally Posted by Hafiz ArslanAli View Post
NO you can't... only 3G supported by this solution.
Read carefully
his unit have a imei so he has a CDMA one
and about cdma its possible to do bypass just need to search and search.
Old 10-15-2014, 08:08   #98 (permalink)
Member: 1459919
Sonork: mhar_89
Thanks Meter: 2
thanks for share ................................
Old 10-15-2014, 08:47   #99 (permalink)
Crazy Poster
Member: 82087
Thanks Meter: 6
My ipad 2 3g , A1396 icloud removed, tested...!!!
Old 10-15-2014, 11:19   #100 (permalink)
kjava's Avatar
Member: 846616
Sonork: 100.1675590
Thanks Meter: 581
my ipad 3 GSM Model 1430 after remove R1204 can not restore firmware (ipad3 wifi firmware)
plz help me anyone
The Following User Says Thank You to kjava For This Useful Post:
Old 10-15-2014, 14:14   #101 (permalink)
Crazy Poster
Member: 1771472
Sonork: 1654650:ICLOUD DIRECT
Thanks Meter: 8
After remove r1204,,its came dfu mode..but in restoring..its come error 4014..please help
Old 10-15-2014, 14:16   #102 (permalink)
Crazy Poster
Member: 1771472
Thanks Meter: 8
Originally Posted by nurettin duman View Post
ipad 2
resistor r1204 ok thank you
it a permanent solution
:d
hello,bro.i also remove r1204...ipad came to dfu mode..but in restoring process its given error 4014...if not hapaning to you?
Please help//ipad 2 gsm
Old 10-15-2014, 16:16   #103 (permalink)
ton1x's Avatar
Member: 258858
Thanks Meter: 96
Attachment 330975
Success bypass ipad mini retina.
Remove r1204, r1205. Jumper r1205 to r1206
The Following 3 Users Say Thank You to ton1x For This Useful Post:
Old 10-16-2014, 01:59   #104 (permalink)
Member: 1260512
Sonork: 100.1605447
Thanks Meter: 461
Need solution for Ipad 2 wifi A1395 & Ipad mini2 wifi A1489.
pls help me all user..........
Old 10-16-2014, 02:13   #105 (permalink)
ton1x's Avatar
Member: 258858
Thanks Meter: 96
Bypass iCloud Activation Lock HardWare Solution!
You can't bypass ipad wifi. Cause modify remove gsm imei to wifi address so that ur ipad become ipad wifi even the ios is gsm ipad
The Following User Says Thank You to ton1x For This Useful Post:
Page generated in 0.18152 seconds with 9 queries
