Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 03-20-2015, 20:56   #1 (permalink)
Member: 2014547
Sonork: 100.1665176
Thanks Meter: 18
iPhone 5s Front Camera broken connector !!!
Hello guys, i got this iPhone 5s with on-board broken front camera connector, so i have to replace this little connector with a new one, i've already bought it from hong kong, but i've never experienced this sort of repair, i don't want to broke / move anything on the motherboard, can you help me with some suggestion?
Old 03-21-2015, 00:23   #2 (permalink)
Member: 2050751
I think it need to replacement new connector only.
Old 03-21-2015, 11:57   #3 (permalink)
Member: 2014547
Sonork: 100.1665176
Thanks Meter: 18
Is there any1 who can help me ? I got all the equipment to do it, kapton and hot air gun, but im not sure about temps, can you suggest me please ?
Old 04-03-2015, 20:47   #4 (permalink)
Member: 2289832
Thanks Meter: 48
buy a cheap flex and first try resolder connector there if you cannot, dont try. before unsolder clean area add flux add some fresh solder. I would use solder iron to remove. But you need be carefull
Old 04-03-2015, 20:55   #5 (permalink)
Member: 2289832
Thanks Meter: 48
U can also use hot air and solder iron together. 270 c low flow. 320 c solder iron. Be carefull not to heat cpu.
Old 06-29-2015, 17:46   #6 (permalink)
Member: 2014547
Sonork: 100.1665176
Thanks Meter: 18
thank you for the tips
Old 06-30-2015, 07:51   #7 (permalink)
Member: 2393796
Thanks Meter: 10
just use a small iron to remove and replace use flux.
make the pads flat no points with new solder use flux gel will help keep the connector in position. keep a tiny bit of pressure on the connector once in place with a small screwdriver or pin, solder a couple of legs at the ends to hold it there while you solder the rest.
try and keep the connector flat as possible to the board.
Page generated in 0.14351 seconds with 8 queries
