02-06-2013, 00:55 | #16 (permalink) |
No Life Poster Join Date: Oct 2010 Location: Abidjan Age: 38
Member: 1418143 Status: Offline Thanks Meter: 353 | sometime I lost Ic or Board pins due to it ... OMG ,, who will briing easy thing to remove it ? |
02-09-2013, 09:44 | #17 (permalink) |
No Life Poster Join Date: Aug 2005 Location: Treasure Island of the pacific
Member: 168090 Status: Offline Thanks Meter: 92 | it's just so silly because sometimes the black glue extends to other parts that makes it more harder to remove the desired ic.. Sent from my year one phone using Tapatalk |
02-12-2013, 00:43 | #19 (permalink) |
Freak Poster Join Date: May 2007 Location: San Jose, Costa Rica Age: 47
Member: 504871 Status: Offline Thanks Meter: 165 | I just like to add a little comments. I ALWAYS clean PCB after work with an cheap toothbrush! Yes, low cost tool I know but 100% good. Maybe professional tools in market, just choose. But te thing is when you desolder/solder any IC on board, small pieces of welding beads can freely get stucked between pcb components. So, I clean ALL the PCB with my toothbrush! Sometimes with thinner (to clean flux (if conductive), somethimes dry. Try and look your final work very clean. BTW, I was searching solutions for "Black epoxy", an this is what I found: ...... FIRST OF ALL: some chemicals listed here are CANCER CAUSING SO BEWARE!!!!.... how to remove epoxy resin and smd chips - YouTube We used to make our own by *slowly* adding sodium hydroxide pellets (one at a time; wait until pellet is dissolved before adding another) to 100% ethanol. A good, muddy brown color usually indicates the ethoxide is ready to use. You won't need much, only a few microliters to cover the section on the slide. Also, monitor carefully. The dissolution of the epoxy occurs fairly rapidly. Epoxy Removal from Gold Fingers http://********.com/2010/07/16/decap...uits-with-sap/ One of the biggest hurdles in this process has always been just getting to the guts of the chip. He used acetone to dissolve the plastic case but had trouble getting through the epoxy blob. Commonly, the epoxy is soaked in nitric acid for a few minutes but [James] didn’t have access to that chemical. Instead he popped into the local music store and picked up some rosin (used to make violin bows sticky enough to grab the strings of the instrument). After boiling down the rock-hard rosin and the chip for 20 minutes, he got a clean and relatively undamaged semiconductor that he can easily peer into. |
The Following User Says Thank You to Argento7 For This Useful Post: |
02-12-2013, 00:58 | #20 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Moldova,Chisinau. Age: 38
Member: 1017374 Status: Offline Thanks Meter: 2,594 | Quote:
02-12-2013, 15:56 | #21 (permalink) |
Insane Poster Join Date: Dec 2007 Location: Brasil
Member: 658949 Status: Offline Thanks Meter: 13 | A person told me that a toothbrush is very electrostatic and recommended that I stay away. This same guy recommended to use 450°C and medium air flow to solder/dessolder SMD components from iphone motherboard. As I can read from experts on this forum this is not true. I don't know what I think. Sorry my English and thanks. |
03-18-2013, 19:28 | #23 (permalink) |
Junior Member Join Date: Dec 2011
Member: 1703094 Status: Offline Thanks Meter: 2 | Hi mr wites !!! Please can you post educational videos for change/repair PFC touch screen conectors for iphones and soldering 01005 smts .... Thank you for helping us !!! You are very good !!! Best regards |
03-20-2013, 11:54 | #24 (permalink) |
Member: 1017374 Status: Offline Thanks Meter: 2,594 | Thanks i will try to make time and make some videos have allot of work. |
The Following 5 Users Say Thank You to Wites OM Tesla For This Useful Post: |
05-05-2013, 13:28 | #26 (permalink) |
Freak Poster Join Date: Nov 2012 Location: Denmark
Member: 1839857 Status: Offline Thanks Meter: 46 | Hello friends, I just wanted to share a method I have started using for removing the black resin surrounding the BGA chips. It has proven very good and is a lot faster than dental-pick and hot-air! Enjoy |
The Following 4 Users Say Thank You to jegerjon For This Useful Post: |
07-09-2013, 08:33 | #27 (permalink) | |
Freak Poster Join Date: Jun 2007 Location: banglore\kerala
Member: 523496 Status: Offline Sonork: ammachis Thanks Meter: 76 | Quote:
1.apply flex and put the reworking heat in the normal ic mode 2.find a gap to insert the knife in to the ic while applying the hear try to remove the glue layer nicely sideways 3keep in mind that there are copper tracks under the ic dont harm it while removing the ic its a simple work but there is no vedio to upload with me so search it goodluck | |
07-14-2013, 09:12 | #29 (permalink) |
Freak Poster Join Date: Feb 2011 Location: usa
Member: 1520201 Status: Offline Thanks Meter: 4 | do someone know more abut this "low temperature solder" ? its more easy to put a new battery connector and more PFCs when you use low temperature right? i have tryed to look for it on ebay but its very expensive |
07-15-2013, 21:15 | #30 (permalink) |
Member: 1017374 Status: Offline Thanks Meter: 2,594 | CyberdocQuick Alloy Use Only to Unsolder Connectors! It is very useful to unsolder some connector even reuse it on other fone but i not recommend it to solder back any connector because it will give crack with time pass,so use it only to unsolder! |
The Following User Says Thank You to Wites OM Tesla For This Useful Post: |
