07-10-2018, 06:30 | #1 (permalink) |
Freak Poster Join Date: May 2008 Location: Las Pinas City Manila Phil. Age: 40
Member: 779009 Status: Offline Thanks Meter: 159 | iP Box V2 Read info Nand I.C problem HELP! Like iPaad 2 32bit and iPad 3 32bit or any 2,3,4 READ PROBLEM Nand I.C (>>> Tips:This hard drive,boot area has a variety of modes ca choose cheir own!!!) after re insert Paid Serial & WiFi w/ Bluetot updating full done & RESTORE iTune or 3utool a Probelam ALWAYS ( WAITING FOR IPAD ) again i remove nand and checked using ip box v2 but,,, that time shows all info erased & insert agaid Paid Serial & WiFi w/ Bluetot updating full done & after that same error ( WAITING FOR IPAD ) |
07-11-2018, 14:35 | #4 (permalink) |
Freak Poster Join Date: Oct 2011
Member: 1675922 Status: Offline Thanks Meter: 61 | After first write, select boot mode 2 and write again On first restore it won't work on 3utools because not able to read SN in recovery mode (don't know why). So first restore should be made on iTunes. When ipad come in Normal Mode should stay for a while on "Verifying ...", and that means the NAND is soldered OK. After that, the restore process should start... If stay only for 1-2 second means that is not able to read nand. |
The Following User Says Thank You to mcmihai003 For This Useful Post: |
