10-24-2011, 09:45 | #1 (permalink) |
Junior Member Join Date: Jan 2008
Member: 681965 Status: Offline Thanks Meter: 4 | iPad 2 Backlight? Coil Location? Is there a coil like on the 3GS I can replace? If anyone know the location I will be forever appreciative. Thanks |
10-24-2011, 10:17 | #3 (permalink) |
Freak Poster Join Date: Aug 2003 Location: west malaysia Age: 56
Member: 36425 Status: Offline Thanks Meter: 4 | Did you soft your problem ,i have the same problem before change touch pad all ok.same as you after cleaning no light even change lcd.........can share you solution......... |
10-24-2011, 11:17 | #4 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Moldova,Chisinau. Age: 38
Member: 1017374 Status: Offline Thanks Meter: 2,594 | Quote:
some small black filter that can easily jumped. | |
11-21-2011, 03:04 | #5 (permalink) |
Member: 681965 Status: Offline Thanks Meter: 4 | still have this problem, anyone else experienced anything like it?? I have checked and replaced all black filters around. Still no backlight.. help is anyone has is much appreciated. |
11-21-2011, 11:53 | #6 (permalink) | |
I would suggest to check all coils for continuity "beep" with multimeter. | |
The Following User Says Thank You to Wites OM Tesla For This Useful Post: |
12-08-2011, 10:49 | #9 (permalink) |
No Life Poster Join Date: Apr 2002 Location: The Green Mile
Member: 11325 Status: Offline Thanks Meter: 266 | i tried with a new LCD and same problem. Will try the mentioned connection and will be back with results. However there must be some other place to connect to the mother board instead to the LCD connector (LED1). |
12-08-2011, 13:02 | #10 (permalink) |
Freak Poster Join Date: Oct 2011
Member: 1679608 Status: Offline Thanks Meter: 190 | you can make jumper between the cap near the coil and ic to the another part in the mother board but we dont have schematic for ipad2 thats why we make jumper from the cap directly to the LCD |
12-08-2011, 14:38 | #11 (permalink) |
Member: 11325 Status: Offline Thanks Meter: 266 | strange but cannot find the shown point on the LCD section. uncovered the tall black plastic parts that is covering the pcbs on the top and lower sections but near the ribbon connector the one i have here which is a 16gb 3G is not like that. |
12-08-2011, 14:49 | #12 (permalink) |
Member: 11325 Status: Offline Thanks Meter: 266 | the P/N of the pcb connected onto the LCD in my case is 6870S-1119K (shown under the tape where there is the main LCD connector. thanks for any help |
12-08-2011, 21:49 | #13 (permalink) |
Member: 11325 Status: Offline Thanks Meter: 266 | Anyone can check to which pin on the ribbon connector on the motherboard is the cap (or LED1 in the picture) connected to pls as have no other ipad 2 to compare to? thanks |
