06-22-2021, 09:41 | #1 (permalink) |
Junior Member Join Date: Mar 2010
Member: 1254276 Status: Offline Thanks Meter: 4 | iPad 7th Gen A2198 wifi issue after hardware bypass |
06-22-2021, 10:23 | #2 (permalink) |
No Life Poster Join Date: Feb 2009 Location: inside apples a15
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 253 | do you have zxw?did you check all pins from wifi connections in diode mode?im sure its not wifi chip now if you replace 3rd time but you already tried 6 times and stil same..there could be another problem.. |
06-30-2021, 10:15 | #8 (permalink) |
Freak Poster Join Date: Oct 2014
Member: 2277735 Status: Offline Thanks Meter: 215 | Ok so you need magiccfg, unbind WiFi in app should work. As said you need to put in digi mode (purple mode) read pad in magiccfg and click unbind WiFi. If that’s not problem then it is WiFi module of bad solder/pads on or around WiFi. https://magiccfg.com/ Last edited by P3T3; 06-30-2021 at 10:16. Reason: https://magiccfg.com/ |
07-02-2021, 09:39 | #9 (permalink) | |
Member: 1254276 Status: Offline Thanks Meter: 4 | Quote:
07-24-2021, 16:22 | #11 (permalink) |
Major Poster Join Date: Dec 2007 Location: tunisia Age: 40
Member: 644590 Status: Offline Thanks Meter: 4 | Please How to convert ipad 7 A2200 to wifi version?? Hi ,please how to change A2200 cellular version to Wifi version?? ,i can’t find any schematic or solution that explain wish resistor to jump or remove ;thanks 🙏🙏 |
12-07-2021, 12:09 | #13 (permalink) | |
Insane Poster Join Date: Sep 2010 Location: romania
Member: 1395362 Status: Offline Sonork: 100.1604590 Thanks Meter: 16 | Quote:
08-18-2022, 15:40 | #14 (permalink) | |
Freak Poster Join Date: Jun 2011 Location: Toronto Canada
Member: 1599578 Status: Offline Sonork: 8114214 Thanks Meter: 131 | Quote:
