Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 05-09-2018, 14:50   #1 (permalink)
Member: 2643514
Thanks Meter: 28
ipad air 2 Not Charging
ipad air 2 only charges when dead. No charge after its ON. have replaced U2 ic and also charging port. Does it have Q2 or any ic like the iphone?
Old 05-09-2018, 19:32   #2 (permalink)
Member: 2498972
Thanks Meter: 33
There's a good chance it is the PMIC itself, a very expensive repair. Before that though, check the Q8804 circuit, that is the MOSFET switcher ofr VCC_MAIN. You should also check the Q8823 circuit as that is the reverse voltage protection circuit.
Old 05-10-2018, 10:58   #3 (permalink)
Member: 2643514
Thanks Meter: 28
thanks brother ill check that and post results
Old 05-11-2018, 18:35   #4 (permalink)
Member: 1211915
Sonork: 345634564
Thanks Meter: 93
did you fix it please tell result?
Old 05-15-2018, 21:25   #5 (permalink)
Member: 2643514
Thanks Meter: 28
hi no still working on it... been busy with other stuff. ill test it in the morning and post results.
Old 09-06-2018, 19:03   #6 (permalink)
Member: 2691507
Thanks Meter: 100
Since mawagas never return with results I'll refresh this trend with an issue.
Working on iPad Air 2, after Nand upgrade it will not go in DFU mode.
These are my findings so far.
1- ipad detected by itunes
2- with Nand on board it will get stuck in "waiting for ipad"
3- without Nand on board it will error 4014 (it didn't after pulling Nand test)
When power on there is power from USB and there is also power coming from batttery
But when is time to switch to DFU battery will not kick in and that why the "waiting for ipad"
(No Power around Nand)
I already test it and it is not charging the battery at all even that power is flowing.
Q8804 has 4.2v (battery)
Q8823 5.0v (when connected to usb)
I have schematics and been checking continuity around Nand caps without any luck.
No pull pads or damage to the under laying Nand just few scratches from cleaning out glue.
I know there are several post on this forum, but none of them are finish or post back how it was fixed.
I know some logic got damage somewhere I just can't find it so I'm now asking for help.
ZXW Dongle renewal on the way {green}
Old 09-11-2018, 17:55   #7 (permalink)
Member: 2691507
Thanks Meter: 100
Main board is drawing 0.64 A when plug to usb and it starts to charge some times some times not.
Already tested with several good usb lightning cables.
External power supply
Tested with couple batteries same resut
Battery sense reading 2.3v (schematic 2.5v) should be ok
1- Already changed tristar.
Any ideas ???
Old 09-13-2018, 02:48   #8 (permalink)
Member: 2691507
Thanks Meter: 100
Any ideas ???
Replaced SRAM, same....
Old 09-15-2018, 07:05   #9 (permalink)
Member: 2691507
Thanks Meter: 100
Ok this is fixed and don't know how.
All I did was to change couple caps C8453 & C8454 and now I'm getting 0.25 A drawn and battery seems to have charged in couple hours.
So the case of not charging is RESOLVED.
Old 09-17-2018, 06:37   #10 (permalink)
Member: 1211915
Sonork: 345634564
Thanks Meter: 93
Exclamation
IPAD AIR POWER IC NOT POSSIBLE REPLACE,
i See no YOUTUBE REPAIR TECHNICIAN POST ANY VIDEO PROOF
no video proof power ic replace youtube IPAD AIR
NOT POSSIBLE
Page generated in 0.20571 seconds with 8 queries
