Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 07-08-2020, 10:24   #1 (permalink)
Member: 2114773
Thanks Meter: 20
iPad Air 2 USB device not recognised after NAND change
Hope someone can help me with this
First befor i remove Nand ipad works just it had icloud,after removal and change serial number and solder it back ipad usb not reconised by pc,i remove nand and conect to pc without it,same problem,i see on forum that pc must reconise it without nand to.Cpu and Ram was protected with temp. tape, 20cent coin and shield
-try 5 diferent usb cable
-2 diferent pc
-no heat on board
-cpu cold
-no short on caps
-no missing caps
I dont know what to do and i remove u2 on end just to try something and one pin is missing ,dont know is that pin cause the problem and where it go,dont have for this model a pcb layout.
here is a photo from U2 missing pin
and here how i protect CPU and RAM
https://ibb.co/HYQ2RJt
Old 07-08-2020, 10:37   #2 (permalink)
Member: 2114773
Thanks Meter: 20
https://ibb.co/5nHPYpn
Old 07-08-2020, 10:57   #3 (permalink)
orx
orx's Avatar
Member: 1825965
Thanks Meter: 874
check image for print missing and try a jumper ..
The Following User Says Thank You to orx For This Useful Post:
Old 07-08-2020, 14:03   #4 (permalink)
Member: 2114773
Thanks Meter: 20
Attachment 376146
cant find that pins can u pls check my motherboard
https://ibb.co/HBNbhTR
Old 07-08-2020, 14:47   #5 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 991
your broken pin is no conection in ipad air2 wifi
no need to conect leave it missing
check another option
replace good cable new ic
The Following 2 Users Say Thank You to chand_gee For This Useful Post:
Old 07-08-2020, 14:54   #6 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 991
yes ipad must be detected in dfu mode without nand ic..
here is software you can use for
https://phoneboard.co/
The Following User Says Thank You to chand_gee For This Useful Post:
Old 07-08-2020, 15:31   #7 (permalink)
Member: 2114773
Thanks Meter: 20
thank you for the software i need it a long time.
the U2 i eplace now same problem cant reconise pc
Page generated in 0.15564 seconds with 9 queries
