04-02-2013, 18:27 | #1 (permalink) |
Freak Poster Join Date: Sep 2005 Location: U.A.E Age: 43
Member: 182134 Status: Offline Thanks Meter: 16 | ipad2 on off button not work after touch change |
04-02-2013, 18:42 | #4 (permalink) |
No Life Poster Join Date: Mar 2007 Location: q.c phil Age: 42
Member: 461188 Status: Offline Sonork: 1587510 Thanks Meter: 207 | maybe you damage the flex for on off upper right side near volume button open again and replace the flex if you cut it... br shoktong |
01-12-2014, 18:01 | #6 (permalink) |
Junior Member Join Date: Aug 2011
Member: 1631602 Status: Offline Thanks Meter: 2 | Seen this recently. Sounds like the cable to the main board is not quite home to me. 3 of them. one to screen, one to Digitizer, and one that links to the board that goes from side(LHS) around the top toward the camera and on/off switch. It is this one that doesnt sound like it's quite home. There are 2 white lines on the cable, and these should be just visible from the top if the cable is pushed home correctly. Make sure the ribbon connectors are home. there should be no white line showing when its seated correctly |
