05-07-2010, 18:16 | #256 (permalink) |
Junior Member Join Date: Feb 2010
Member: 1224858 Status: Offline Thanks Meter: 6 | Looking for someone with a 3G iphone logic board and a multi-meter I'm looking for a bit of help from anyone that has a logicboard/motherboard from an iPhone 3G to hand, and a multi-meter… I had to re-attach one of the ins of the SIM card carriage, due to it shearing off when the SIM card tray was inserted the wrong way round - not by me! So I re-soldered the damaged SIM carriage on to the little of the contact that was left on the Logicboard (point A on attached photo) which all went well… But whilst checking the board with a multimeter I have noticed that there is continuity between the pin I re-soldered and point B on the photo, or any of the other pieces of metal shielding (I presume this is ground). I don't want to put the phone back together and power it up only to realise something is shorting out and **** a load of components… So I would be really grateful if soon could confirm if there should be continuity (connection) between the 2 labeled points (A and B) ? Cheers Oliver |
05-07-2010, 18:59 | #258 (permalink) |
No Life Poster Join Date: Nov 2005 Location: CHILE
Member: 196727 Status: Offline Thanks Meter: 419 | [QUOTE=mr_oj;5810404]Hi Guys, I'm looking for a bit of help from anyone that has a logicboard/motherboard from an iPhone 3G to hand, and a multi-meter… I had to re-attach one of the ins of the SIM card carriage, due to it shearing off when the SIM card tray was inserted the wrong way round - not by me! So I re-soldered the damaged SIM carriage on to the little of the contact that was left on the Logicboard (point A on attached photo) which all went well… But whilst checking the board with a multimeter I have noticed that there is continuity between the pin I re-soldered and point B on the photo, or any of the other pieces of metal shielding (I presume this is ground). I don't want to put the phone back together and power it up only to realise something is shorting out and **** a load of components… So I would be really grateful if soon could confirm if there should be continuity (connection) between the 2 labeled points (A and B) ? Cheers Oliver..... .... Hi my ingles is bad , tienes problema de un corto levanta el pin A que no toque directamente la mainboar y has un jumper con la foto que deje en mi otro post saludos nafg |
05-17-2010, 10:38 | #259 (permalink) |
Junior Member Join Date: Sep 2009
Member: 1114125 Status: Offline Thanks Meter: 0 | NAFG can you handle this (160x error) Hello all!Help needed with two iphones 3G 8GB.With same error 160x. 1.First iphone : when i plug the cable it shows battery sign but no charge, i can put in DFU and wont restore (error 23).After i disansembled and look carefully at all flat cables and ansambled back it show nothing on screen (just a few lines when i put in dfu mode)When i try to restore gives a error 160x (1601 mostly). I have tried x variants on x PC (even MAC) and same error.I think is something HW. 2.Second iPhone was dropped down and display was broken so i changed the lcd and it works but when i put all screws back and ansambled him it show nothing...black display same lines on DFU same error on DFU. Any help woud be apreciated. Thanks in advance. BR Gsmparts |
05-25-2010, 23:13 | #262 (permalink) |
No Life Poster Join Date: Nov 2007 Location: romania Age: 40
Member: 631660 Status: Offline Thanks Meter: 139 | nafg plz help me ...i have one piece iphone 3gs 32 gb ...after connecting bad charger in it ..phone stopped working...enterred in recovery mode (itunes+cable on screen) tried flashind tried all...in your earlier post said...repaired 30 piecees this way... when i try restore...always error 6 cannot restore..that bar always not starting..showing but nothing... can you tell me which parts to check? i cannot find any schema or diagrams for 3gs with this error thanks in advance |
05-25-2010, 23:40 | #265 (permalink) |
Freak Poster Join Date: Apr 2008 Location: Cracow
Member: 739941 Status: Offline Thanks Meter: 111 | Hello every one is any body have got datasheet for this Code: INFINEON SMP3i SMARTi POWER MANAGEMENT IC http://www.infineon.com/cms/en/produ...19ebec03f05327 and is some body know for what is that part under the iron?? (iphone 3GS) |
06-04-2010, 08:38 | #269 (permalink) | |
Member: 1114125 Status: Offline Thanks Meter: 0 | Quote:
Schimba ltc4088 care este controllerul usb si incarcare.Am la 30 lei buc.Nu iti pot da mai mult de 2 buc.pentru ca de abia am reusit si eu sa fac rost de 12 buc. | |
iPhone 3G S Diagram Here | delower10 | iPhone, iPad, iPod Hardware Repair | 11 | 12-27-2010 14:57 |
IPhone 3g broken motherboard no service | Farntet | iPhone 4 / iPhone 4S | 4 | 11-25-2010 11:51 |
iphone 3G MotherBoard Diagram------By {{{Rasel--Wingstel--Bangladesh}}} | Wingstel | iPhone 2 / iPhone 3G / iPhone 3GS | 4 | 01-27-2010 12:26 |
iPhone 3G S Motherboard Diagram by parts | Zulea II | iPhone 2 / iPhone 3G / iPhone 3GS | 0 | 11-23-2009 08:03 |
