12-07-2010, 10:05 | #2 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Philippines Age: 36
Member: 758106 Status: Offline Sonork: jap_line Thanks Meter: 412 | check antenna first (number 6) try to replace it and check again if still grey out if no luck, check coil above bt/wifi ic and capacitor on the left side i fixed more than 5 pcs 3gs no wifi problem and all solved be careful, do it step by step post result Br. |
The Following 2 Users Say Thank You to jap_line For This Useful Post: |
12-07-2010, 11:49 | #3 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: lebanon Age: 49
Member: 141363 Status: Offline Sonork: 100.1594362 Thanks Meter: 148 | Quote:
br | |
The Following User Says Thank You to enzawigroup For This Useful Post: |
12-15-2010, 21:19 | #6 (permalink) |
Freak Poster Join Date: Nov 2010 Location: Earth and around
Member: 1442842 Status: Offline Thanks Meter: 103 | right! it's the wifi IC. Change it, or try to warm it up with HotAir Solder. Some IC work after this procedure. I have 3 Phones they work with upheating since 3 month without problems. Some other i must change the IC . But work very carefully!! |
The Following User Says Thank You to it-repair For This Useful Post: |
01-11-2011, 11:41 | #9 (permalink) |
Crazy Poster Join Date: Nov 2010
Member: 1448091 Status: Offline Thanks Meter: 9 | I had the same problem, fixed it with this: YouTube - iPhone WiFi Repair: Heat Gun Reflow After the third time reflowing with the heat gun my wifi started to work again. I reflowed the wifi the third time a bit longer than in the tutorial and I also heated the bluetooth ic (the long one next to the wifi) Hope I could help! |
The Following 2 Users Say Thank You to goashu For This Useful Post: |
02-09-2011, 01:00 | #10 (permalink) |
Junior Member Join Date: Feb 2011 Location: Upstate NY
Member: 1511860 Status: Offline Thanks Meter: 1 | Where can you get these coils mentioned ? Does anyone have a diagram of coils and part numbers for them ? |
The Following User Says Thank You to Captain X For This Useful Post: |
02-09-2011, 02:39 | #11 (permalink) |
Freak Poster Join Date: Jan 2010
Member: 1216441 Status: Offline Thanks Meter: 25 | before execution the hardware.... prefer execution the software...like restore or reset network setting (some people solved with this one) |
The Following User Says Thank You to AutoDelete For This Useful Post: |
02-11-2011, 22:33 | #13 (permalink) |
Insane Poster Join Date: Sep 2010
Member: 1387214 Status: Offline Thanks Meter: 17 | You can change the wifi-ic? I'm sorry, but you have an idea around dimensions of this ic? It's very small, is glued with resin (I think) on a square board and around this are a lot of components.. you've tried? |
The Following User Says Thank You to nidirex For This Useful Post: |
02-14-2011, 15:53 | #14 (permalink) |
Junior Member Join Date: Nov 2010
Member: 1448240 Status: Offline Thanks Meter: 6 | best recommend you to buy a spoil motherboard and tried it there. it taken me 3 to 5 3gs motherboard and was even working for some and pay around with it. in which most of it was damage by me in the end. those was bought for me to try. |
The Following User Says Thank You to electrox For This Useful Post: |
02-16-2011, 14:05 | #15 (permalink) |
Junior Member Join Date: Jan 2011
Member: 1491690 Status: Offline Sonork: [email protected] Thanks Meter: 0 | this ic is paysted so how can i chnge plz tel me i have 10 i phon for this fult |
5110v5.29 no network | GSMlearner | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 04-08-2001 17:15 |
Dejans Flasher Problem with 6150, NO Network after Flashing | AboAli | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-03-2001 22:39 |
My 6150 (5.23) No network after Flashing | AboAli | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 01-31-2001 15:56 |
6150 no outgoing calls | edis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-20-2000 20:19 |
no one can unlock 6110 05.40 25-5-99 | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 09-22-1999 08:03 |
