Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 12-09-2012, 13:46   #286 (permalink)
Member: 462642
Thanks Meter: 4
Originally Posted by dictap View Post
Well, that must have been the most fiddliest, rough ending piece of soldering jobs i have ever done (not pretty) had a small tip but used standard solder wire, but damn me its working and charging.
please press thanks button if my solution helped.
Old 12-13-2012, 06:03   #287 (permalink)
Member: 1785720
Not try to hijack the thread, but i have this same situation with the 4S. Is it the same jump location on the 4S ?
Old 12-15-2012, 11:58   #288 (permalink)
Member: 1852979
Question
Hello,
i've got the same problem. I've bought it damaged and thought i could repair it. Problem of it was that the battery connector ways are damaged and the capacitors damaged too.
Is there an other way to repair it?
Old 12-15-2012, 12:29   #289 (permalink)
Member: 1786863
Thanks Meter: 6
Hello,
hello it miss 3 component c20 c12 and fl5 so to make jumper... those capa are 100PF 5% 25v for info and in shematic you can see that one side go to ground the other for c20 where arrive batterie 3 its connected to GAS_GAUGE_CONN and for c12 batterie 2 its conected to
NTC_CONN
clean properly your boardand try to see if there is any possibility to solder new capa or if you reach to catch the VIA and solder it with very little wire or to jump until GAS_GAUGE and NTC_CONN ididnt check what it that but it looklike connector.
good luck
Old 01-10-2013, 20:54   #290 (permalink)
Member: 1866446
Iphone 4 battery connector
Hey,
I damaged one of the resistors when I´ve tryed to solder jump for my battery connector.
Anyone know what to do with the damaged resistor? ( one of the small ones under the metal shield)
Old 01-11-2013, 08:05   #291 (permalink)
Member: 1866668
@GSMan: Could u show me how to fix auto reset on iphone 4?...Thank so much.....
Old 01-23-2013, 11:16   #292 (permalink)
Member: 1872883
Hello everyone I introduce myself am new to this forum as you can see in the photo I have this problem how can I fix it? the iphone will be lit only with the charger inserted, the charge level remains always 100%.
Old 01-24-2013, 12:43   #293 (permalink)
Member: 1508411
Thanks Meter: 36
You need to really clean that board up first so you can see what you're doing.
Old 01-25-2013, 01:11   #294 (permalink)
Member: 1615254
Thanks Meter: 53
Wow! Did you do all that damage yourself? Your wire is WAY too large, looks like your iron is to hot and you have no flux. I'd advise you stop as you will damage it beyond repair.
Old 01-28-2013, 11:21   #295 (permalink)
Member: 1872883
unfortunately I did everything myself, can you tell me how can I restart it after the damage I've done?
Old 01-28-2013, 11:51   #296 (permalink)
Member: 1872883
I cleaned it up, where do I start? thank you and excuse me, really?
Old 02-04-2013, 17:17   #297 (permalink)
Member: 1878904
Hello People ,
I got 2 Iphone 4.
Both fell in the water!!
Iphone 1 :
Cleaned it , I let it dry. Everything works except touchscreen! Its not the screen itself but something on the motherboard , is it the connector or the IC?
Iphone 2 :
Cleaned it , Let it dry!
Everything works but it does not charge and does not turn on with battery. It DOES turn on with a charger.
So there is a short somewhere! Also the 4 VERY SMALL connectors that everybody is rewiring to , the 1 on the upper right is loose! What do i do now? Resolder it?
http://i793.photobucket.com/albums/y...IL/Iphone4.png
Im talking about the very small 4 connectors , not the battery connector!
Thanks!!!
Old 02-04-2013, 17:25   #298 (permalink)
Member: 1878904
Btw , Brod! Does your Iphone work now?
I've been reading through these topics but what are "filters" ? I know what filters are but not on a Iphone 4?
Those small connectors wich are used for jumpers , what are those things? Do i need them?
Old 02-06-2013, 10:08   #299 (permalink)
Member: 599125
One of the 4 really small conductors are broken.
I tried very hard to make a jumper, but how it seems there is no space where it can take some solder...
What should I do?
The phone doesnt charge!
Please help, read this Thread but didnt found any solution
Old 02-06-2013, 13:45   #300 (permalink)
Member: 1878904
I have the same problem , Mine is loose not broken!
Service Provider Lock 1-4 ? StompSC Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 06-27-2012 11:00
sp lock 1,2,3,4 removed spterminator Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 10 08-09-2010 10:20
£2,000 for 5110/6110 unlock software 1 2 3 4 Dean O'Grady Wanted Products 14 03-19-2005 10:52
I CAN UNLOCK 1,2,3,4 FOR ANY PHONE £40 (1+) -- £30 (20+) andrew bennett Main Sales Section 1 07-26-1999 19:33
Page generated in 0.20654 seconds with 10 queries
