01-14-2014, 08:31 | #1 (permalink) |
Junior Member Join Date: May 2008 Location: romania
Member: 769081 Status: Offline Thanks Meter: 0 | Iphone 4 reboot and battery problems I bought an iphone 4 with battery problems, for what the seller told me. I opened it, and the batteri connector is missing from the board, also the solder point for the 2 middle pins are avariated. I soldered an positive wire from battery to board, and the negative one (the 2 middle ones are not connected). What i see now, is that my iphone constantly reboot after 1-2 minutes. This is because i don't connected the 2 middle pins from battery, or is possible that the phone have another problem? I will be home in weekend, so until then i cannot resolve the others 2 pins problem. Also the battery doesnt have anymore the mini board, is just the battery, so i will have to find a new one first. Thank you! |
01-15-2014, 07:19 | #3 (permalink) |
Member: 769081 Status: Offline Thanks Meter: 0 | i found that myself, but the question was about restarting. meanwhile i found some posts where people say if one pin from battery is not connected, that can cause restart (GAS_GAUGE_CONN if i remember correctly). |
01-15-2014, 16:03 | #4 (permalink) |
Member: 769081 Status: Offline Thanks Meter: 0 | is there any ways for battery? i tried the solution posted before today, but the problem is i don't have the 4 capacitors/resistences and also the pins are damaged. somebody must have tried that, and fail...is there any point on the board where i can solder pins 2 and 3? |
