05-31-2015, 15:52 | #1 (permalink) |
Freak Poster Join Date: Sep 2013 Location: Herat/Afghanistan
Member: 2022385 Status: Offline Sonork: 166633 Thanks Meter: 74 | iphone 5s apple logo and black screen is there any solution for that? if anyone has the solution plz share. thanks in advance. |
06-04-2015, 19:52 | #7 (permalink) |
Junior Member Join Date: Mar 2012
Member: 1729446 Status: Offline Sonork: mmaaxxs Thanks Meter: 0 | power it down and try disconnecting the battery let it set for about ten minutes not hooked to a charger ... then reconnect the battery and power it up it has worked for me in the past for those of you that the phone will restore completely with no errors and still blank screen or apple logo boot loop try a different KNOWN GOOD screen...this also works for the dreaded apple logo with nand error |
06-05-2015, 19:40 | #10 (permalink) |
No Life Poster Join Date: May 2015 Location: Los Angeles
Member: 2398349 Status: Offline Thanks Meter: 62 | ok how abt removing ur screen and putting it on DFU mode without screen and restore it. I should work. I've had 2 3 problem like this and had it done. last one was 10 min ago!! |
06-22-2015, 13:41 | #14 (permalink) |
Freak Poster Join Date: May 2015 Location: Ireland Age: 51
Member: 2393796 Status: Offline Thanks Meter: 10 | Just got a 5s which was on activation screen from charge up, then I went out come back 1 hour now in recovery mode blank screen. No idea of its software version, but iTunes says recover not update so I guess its 8.3. Will have to try a new battery and remove screen and try updating. But because its just come in not sure what the battery life is like. |
06-22-2015, 16:42 | #15 (permalink) |
Member: 2393796 Status: Offline Thanks Meter: 10 | Just took mine apart and small amount of water damage near sim slot under shield so have taken shield off and cleaning there at the moment looks like a couple of caps might need replacing but still looking in to that. |
