12-10-2017, 16:38 | #226 (permalink) |
Freak Poster Join Date: May 2008 Age: 48
Member: 772951 Status: Offline Thanks Meter: 146 | iphone 5s not charging iPhone 5s not charging while the battery is empty. if battery is a little bit charged. the charge will work properly. any idea with this problem ? |
12-14-2017, 14:46 | #228 (permalink) |
Freak Poster Join Date: Mar 2013 Location: Madrid
Member: 1898289 Status: Offline Thanks Meter: 39 | have you try with another battery? I had that bad experience with some non original ones. If battery is not the issue. Check if has a little short and up to that amps overused can't get enouth power to reactivate the battery with minimal volts to power it up the phone. When battery is emptier needs more power, you can compare with another working one if you have power supply. If both before were OK is the U2. |
The Following User Says Thank You to mandango For This Useful Post: |
12-19-2017, 18:01 | #229 (permalink) | |
Member: 772951 Status: Offline Thanks Meter: 146 | Quote:
...thk for your answer every you said , i checked.... i changed the battery first with the same result. need to understand wich circuit is faulty. my theory is the system is powered correctly when an IC that give the order to power the battery is not sollcicited.cause the batt has sufficient ^power to power up. and Something reveal that Something broken | |
11-27-2020, 13:24 | #231 (permalink) |
Major Poster Join Date: Nov 2008 Location: phillipines Age: 42
Member: 891579 Status: Offline Sonork: " The Punisher " Thanks Meter: 1 | iphone 5s reboot every 2 to 3 minutes and the battery become 1% after a seconds appear the battery percentage... but after 2 to 3 minutes restart again.. any solution? |
The Following User Says Thank You to jericho28 For This Useful Post: |
11-30-2020, 14:00 | #232 (permalink) | |
No Life Poster Join Date: Mar 2014 Location: Congo Kinshasa
Member: 2148606 Status: Offline Sonork: Bobobokota Thanks Meter: 496 | Quote:
The problem is checked with the filter or resistance next to the battery connector Envoyé de mon iPhone en utilisant Tapatalk | |
