10-16-2017, 13:48 | #1 (permalink) |
Insane Poster Join Date: Mar 2016 Location: Brazil Age: 31
Member: 2553311 Status: Offline Thanks Meter: 6 | iPhone 6 High consume on boot then gets normal, during use reboot I have 3 iPhones with the same behaviour. On boot, they gets over 1.1A on power supply, after that, the consume stays normal, at 0.2A ~ 0.4A, in stand by gets down to 0.016A to 0.030A. But even then, after some time of use, the phone randomly reboots itself. It can turn on normally on power supply due to 2A supply, but on the battery with only 1A maximum supply they keep rebooting itself. Checked some power rails and no short or damaged cap is found, anyone can clarify what rail maybe the cause? Thanks! Ps.: VCC_Main had a cap "bottlecaping" the 4.2v line, changed and the rail is ok now, but the problem persists... |
The Following User Says Thank You to vagner.phillipe For This Useful Post: |
10-16-2017, 16:49 | #2 (permalink) |
Freak Poster Join Date: Jan 2016 Location: Hungary
Member: 2515187 Status: Offline Thanks Meter: 114 | Hello When you press the power button, the current jump immediately around 0.2A? If yes, replace U1700. |
The Following User Says Thank You to Pallle For This Useful Post: |
10-16-2017, 17:09 | #3 (permalink) | |
Member: 2553311 Status: Offline Thanks Meter: 6 | Quote:
At some point on the Apple Logo screen, the current goes to 1,1A, then after the sucessfull boot it remais normal... Some time fiddling with the phone it reboots and everything happens again... | |
10-16-2017, 17:37 | #5 (permalink) | |
I've never had a phone that peaks at 1,1A in system boot, normally goes to 0,8A max. How is it normal to peak at 1,1A since the battery just supply 1A? If the logic board doesnt have the supply necessary it shuts off... | |
