Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 03-08-2018, 16:42   #1 (permalink)
Member: 2804674
iphone 6 won't turn on
I have an iphone 6 that won't turn on!
On diode mode i get:
1.5V at battery fpc connector
1.5V pp_vcc_main
1.5 pp_batt_vcc
can some help me?
Thanks
Old 03-09-2018, 20:21   #2 (permalink)
ninos22's Avatar
Member: 1903358
Thanks Meter: 146
1.5V pp_vcc_main
1.5 pp_batt_vcc
can some help me?
Thanks
What cause the problem?
Put phone in charge and check:
1. Battery connector for 3.8v
2. If battery connector not 3.8v, check C1704 for 5v
3. If C1704 not 5v, check Q1701
The Following User Says Thank You to ninos22 For This Useful Post:
Old 03-10-2018, 03:00   #3 (permalink)
Member: 2784527
Thanks Meter: 9
Yeah ninos22 said right. Nspereira you can try it. if can't work, guess somebody else will help you soon.
Old 03-12-2018, 12:34   #4 (permalink)
Member: 2804674
after putting phone in charge what i get in diode mode is:
1. 1.5V
2. C1704 - 1.5V
3. Q1701 - 2.2V
What should i do next?
Thank you!
Old 03-12-2018, 13:30   #5 (permalink)
ninos22's Avatar
Member: 1903358
Thanks Meter: 146
1. 1.5V
2. C1704 - 1.5V
3. Q1701 - 2.2V
Thank you!
Check C1408 for 5v, if not check with diode mode and post result.
Old 03-12-2018, 16:36   #6 (permalink)
Member: 2804674
1. 1.5V
2. C1704 - 1.5V
3. Q1701 - 2.2V
Thank you!
sorry the values measured before were wrong, correct values are:
C1704 , Q1701 and C1408 - 2.6V
Old 03-12-2018, 19:50   #7 (permalink)
ninos22's Avatar
Member: 1903358
Thanks Meter: 146
Still abnormal.
Check PP_BATT & VCC_MAIN with diode mode
Old 03-13-2018, 14:47   #8 (permalink)
Member: 2804674
Still abnormal.
PP_BATT - 1.2V
VCC_MAIN - 1.5V
what should i do? remove the PM IC?
Old 03-13-2018, 19:20   #9 (permalink)
ninos22's Avatar
Member: 1903358
Thanks Meter: 146
PP_BATT - 1.2V
VCC_MAIN - 1.5V
sorry i don't understand you. How you check this rails with diode mode?
max value in diode mode is 0.99
red to ground
black to components
Old 03-13-2018, 20:04   #10 (permalink)
Member: 2804674
red to ground
black to components
i check the capacitors on that rails, on PP_BATT i checked C1480 and for MAIN_VCC C1418
Old 03-13-2018, 21:48   #11 (permalink)
ninos22's Avatar
Member: 1903358
Thanks Meter: 146
Ok so what is the value in diode mode?
Old 03-13-2018, 23:16   #12 (permalink)
Member: 2804674
the values i get is the one's i said before
1.2V for PP_BATT - C1480
1.5V for PP_VCC_MAIN - C1418
Old 03-15-2018, 15:58   #13 (permalink)
Member: 2804674
can someone help me?
Old 03-15-2018, 16:25   #14 (permalink)
ninos22's Avatar
Member: 1903358
Thanks Meter: 146
I try to help you but you need to answer me, do you know what is diode mode?
Old 03-15-2018, 18:49   #15 (permalink)
Member: 2804674
yes i do my friend, i would put a pic of the multimeter but i need min. 10 posts to do so.
Page generated in 0.28492 seconds with 9 queries
