08-31-2016, 18:08 | #1 (permalink) |
Freak Poster Join Date: Dec 2013 Location: Veneto
Member: 2077335 Status: Offline Thanks Meter: 11 | iphone 6s backlight problem I have here one i6s with no backlight, when i opened it i found that D4020 and D4021 was burnt and (as you can see from the photo) the solder pads on the pcb are damaged because of the burning. is it possible to repair that in your opinion? thanks! |
08-31-2016, 20:42 | #2 (permalink) |
Freak Poster Join Date: Sep 2015
Member: 2453408 Status: Offline Thanks Meter: 63 | if you can dig some copper under protective mask then why not but its very precise work to do check cathode side of these diodes first because probably one of the boost converter output caps are shorted (c4022, c4023) or maybe even ic, check caps first |
The Following User Says Thank You to Kradziej For This Useful Post: |
08-31-2016, 21:36 | #3 (permalink) |
Major Poster Join Date: Jan 2010 Location: Europe
Member: 1208225 Status: Offline Thanks Meter: 13 | easy Very easy job. Look at my pic, and use some wires to make the connection on the missing pad size |
The Following 4 Users Say Thank You to gkhn For This Useful Post: |
10-01-2016, 11:27 | #8 (permalink) |
Junior Member Join Date: Oct 2011
Member: 1665307 Status: Offline Thanks Meter: 3 | Hi, iPhone 6s backlight doesn't work. where to start to measure? FL4211, FL4212, and see if it beeps? then go under the shield to check doide's? Thanks |
The Following User Says Thank You to reparatieplus For This Useful Post: |
