Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 01-12-2018, 20:49   #1 (permalink)
Member: 1819464
Thanks Meter: 88
iPhone 6S won't activate after NAND replace
Hello everyone,*
I have got a problem with an iPhone 6S after I replaced the NAND.*
Basically. the phone came in with error 9. I took out the NANS and used WL PCIE tool to read it. WL won't read it, so the NAND was dead completely.*
I took another NAND from another board, used WL to change the Serial Number (took it form the i6S box) and place it on the board.
The iPhone restores fine, it has IMEI, ICCID, SN and MEID. It recognises the SIM, is taking full cellular reception, WI-FI is working but it won't activate.*
I get this message: " The iPhone "iPhone" could not be activated because the activation information could not be obtained from the device"
Any help?
Is there a way to fix it?
Does anyone uses WL and had the same issue?
Have I missed something?
Thank you all!
Old 01-13-2018, 05:00   #2 (permalink)
Member: 2777379
Thanks Meter: 34
Are you sure the IMEI is clean?
Old 01-13-2018, 07:42   #3 (permalink)
Member: 89550
Thanks Meter: 8
Did you write WiFi And bt mac address to nand ic from original information?
Old 01-13-2018, 07:44   #4 (permalink)
Member: 2428367
Sonork: 193.393.394.1
Thanks Meter: 219
use gsx to get the originial information for your iphone 6
and write these informtion to nand
everything wil be ok
Old 01-13-2018, 12:28   #5 (permalink)
Member: 1819464
Thanks Meter: 88
Access not provisioned
Thank you very much for your help.
I do have an problem login in to the gsx.apple.com.
I get this message: "Access not provisioned"
Old 01-13-2018, 12:29   #6 (permalink)
Member: 1819464
Thanks Meter: 88
The original NAND was completely dead, couldn't read the original info from it!
Old 01-18-2018, 06:30   #7 (permalink)
Member: 89550
Thanks Meter: 8
You can buy from this SimKilitBayi.Net
Old 06-07-2018, 19:29   #8 (permalink)
Member: 434661
Thanks Meter: 3
Did you manage to do it at the end? I've got similar problem with iPhone 7
Page generated in 0.19139 seconds with 8 queries
