Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 04-29-2020, 20:26   #1 (permalink)
Crazy Poster
Member: 1748637
Thanks Meter: 5
iPad Pro 10.5 a1709 after replace display auto-restart every 2.40min
iPad Pro 10.5 a1709 after replace display auto-restart every 2.40min. Please help me
Old 05-08-2020, 21:29   #2 (permalink)
Member: 2277735
Thanks Meter: 215
Same issue, problem is one of the digitiser filters/resistor has ****n... My iPad fine in standby but not when using it it restarts. Need to work out the ****n point!
Old 05-27-2020, 08:19   #3 (permalink)
HDccam's Avatar
Member: 1732818
Thanks Meter: 532
Sounds like the ipad can not read the battery status. Check if you can read battery info, Check the small battery connector pins and screw pressure.
Old 06-24-2020, 10:15   #4 (permalink)
Member: 2277735
Thanks Meter: 215
My issue is not battery, put the logic board in a different housing and still the same.
Old 07-01-2020, 21:52   #5 (permalink)
Member: 2277735
Thanks Meter: 215
Ok so after testing it was my screen, brand new screen did this. I got another working iPad and tested the screen, restarted every few min.
I have ordered a new screen, I’m hopping will be hear any day but just because it’s a new screen it could still be issue, nearly used a good iPad for parts because of this so be careful.
Just make shore you always disconnect battery before removing screen and that way if you get a faulty screen you will know 99% it’s the screen!
The Following User Says Thank You to P3T3 For This Useful Post:
Old 07-09-2020, 19:47   #6 (permalink)
Member: 2277735
Thanks Meter: 215
New screen fixes this 100%, tested!
I noticed new screen dos not try to pair True Tone (no option) where as restarting screen had True Tone setting and was not programmed or paired with LB so I’m thinking this is the issue?!
Page generated in 0.12167 seconds with 8 queries
