05-19-2021, 09:47 | #1 (permalink) |
Freak Poster Join Date: Feb 2008
Member: 706023 Status: Offline Sonork: 100.1647210 Thanks Meter: 75 | iphone 7 (intel) unable to activate Customer come to my store with a Ipone 7 intel version with hang on apple logo I tried to restore and get error 4013 then I desolder nand and did format with jcpro and resolder the nand, restored with itunes and get to activation menu when I tried to acitvate but, I get "Unable to Activate" error, what I did to resolve this error: 1.Changed nand 2.Changed tirstar 3.Changed nfc ic and nfc boost ic 4.Changed tigris 3.Reballed baseband ic 4.Changed audio ic 5.Changed baseband power ic I checked all didoe's value is normal and in 3UTools I can see the imei and baseband version even I inset a simcard to the device and I get service too. Is there any solution to sovle this error. Thanks in advanced. |
The Following User Says Thank You to parvizhamidi For This Useful Post: |
05-19-2021, 11:18 | #2 (permalink) |
No Life Poster Join Date: Feb 2009 Location: inside apples a15
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 253 | hope your serial and mac adress of wifi and bluetooth is stil same as in the baseband..you did a lot of hardware maybe you have wrong info from nand thats why it connot activate and also maybe apple activation server has changes also in new ios update.. |
The Following User Says Thank You to simpleprince49 For This Useful Post: |
05-19-2021, 11:26 | #3 (permalink) |
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 253 | jailbreak your phone and use this tool to read its serial an mac adress from the phone and compare it to the one that you have in 3utools ****************************/file/y3jyp..._Guru.zip/file |
05-19-2021, 11:42 | #4 (permalink) |
Member: 706023 Status: Offline Sonork: 100.1647210 Thanks Meter: 75 | Thanks for your advice, I think the mac address of wifi and blutooth is same as in the baseband chip becuse I can connect to wifi without any problem. |
The Following 2 Users Say Thank You to parvizhamidi For This Useful Post: |
