Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 11-15-2009, 12:10   #1 (permalink)
Member: 188329
Thanks Meter: 8
iphone back light solution
the problem is usally while changing lcd and water damage.. anyway i dont need tell something.. write me any problem software and hardware i help you.. now look at the picture and you"ll see im sorry i could not ad picture i dont know why.. contack with me its very easy
The Following 6 Users Say Thank You to mertt For This Useful Post:
Old 11-15-2009, 14:42   #2 (permalink)
rimjhim's Avatar
Member: 718146
Sonork: 100.1619088
Thanks Meter: 118
bro. first show ur i phone pic..
Old 11-16-2009, 09:52   #3 (permalink)
55533faisal's Avatar
Member: 748991
Thanks Meter: 175
iphone 3G MotherBoard Diagram
The Following 2 Users Say Thank You to 55533faisal For This Useful Post:
Old 11-17-2009, 17:32   #4 (permalink)
bluejack22002's Avatar
Member: 741453
Thanks Meter: 43
Hi Mertt, please send me the iphone back light solution??? damage when changing lcd. please help me!! thanks
Old 11-17-2009, 23:12   #5 (permalink)
Member: 1163420
Thanks Meter: 10
I dont like duplicated posts, so i continue here.
@mertt
Send the picture to one of us and we upload it to the forum. I will be very grateful.
Old 11-19-2009, 10:52   #6 (permalink)
Member: 1163420
Thanks Meter: 10
mertt send me an email today, with this image :
He seems to say, that we must change those to make the backlight work properly.
The Following 10 Users Say Thank You to Dexter55 For This Useful Post:
Old 11-23-2009, 20:31   #7 (permalink)
Member: 177515
Greetings everybody.
I ve iPhone 3G 16GB, no backlight as soem other of us :-)
I guess I did a shortcut while I was connecting the connector nr1 (i pressed it too much to left).
(Or the flexcable went off as I bend it too much).
I did not changed my LCD yet but I have ordered it already.
My motherboard looks different than one on the picture above.
Any of You repaired that backlight yet?
By changing the parts in red circle?
Anyone has an idea witch of the pins in the connector nr 1 gives the current to a backlight?
I wish to be sure there is NO juice there before I desolder anything on the MB.
Be well folks!
Cuba
Old 11-24-2009, 00:37   #8 (permalink)
cpr.orlando's Avatar
Member: 843747
Thanks Meter: 40
Clean the connection on the board and lcd flex with a stiff toothbrush and alcohol not the cheap stuff you have
in you bathroom, go to CVS or Walgreens or a Walmart get the 91%+ alcohol not the 70% stuff (water is what got
you in this mess) clean the water damaged locations and use a heat gun ot a HOT hair dryer to dry things up
if it still dosent work then the lcd has been shorted out REPLACE then lcd..
Old 11-24-2009, 00:40   #9 (permalink)
Member: 140207
Has someone try this solution and did it work?
Old 11-27-2009, 10:13   #10 (permalink)
Member: 177515
welll in my case it was broken felx ribbon that turned the light off.
Old 12-01-2009, 12:27   #11 (permalink)
amanvir's Avatar
Member: 231737
Sonork: 100.1606447
Thanks Meter: 163
Yes wid ur solution i fixed my phone as u told me i have to change d coil wid any nokia bb5 phone, i take d coil form my non working nokia n70 phone and put it on my iphone 3Gs everything working fine............
Br.
amanvir
Old 12-12-2009, 19:44   #12 (permalink)
Member: 1182189
Hi there... so, to solve this problem a coil change is needed? or just welding a bridge or something like that? can anyone explain a little bit more? thankss
Old 12-12-2009, 20:42   #13 (permalink)
amanvir's Avatar
Member: 231737
Sonork: 100.1606447
Thanks Meter: 163
take coil from any bb5 damage phone and replace wid ur iphone, it will work 1000%
The Following User Says Thank You to amanvir For This Useful Post:
Old 01-04-2010, 15:52   #14 (permalink)
ebry's Avatar
Member: 127240
Thanks Meter: 82
Thank you guys. New coli solve my problem.
The Following User Says Thank You to ebry For This Useful Post:
Old 01-05-2010, 03:39   #15 (permalink)
Member: 895524
Thanks Meter: 33
really depends the situation your are in GUYS .
But i would always suggest to inspect both the connectors for you LCD and the main board LCD connector.
Clean, or clean and resolder the joins if there any corrosion, if still dont work change LCD, if it doesnt work still wash the board and use ultra sound cleaning device/washer, if it still dont work try reheat or try changing new coils on the board .
to take coil out you will need a plastic weller(desolder), heat chip about 450degree and should come off. then resolder it. Word of advice stay away from the black sealer bits, it might heat up and bust your board >.<
Also another general rule when REPLACING IPHONE LCD SWITCH OFF THE DARN PHONE
The Following 3 Users Say Thank You to kawaichang For This Useful Post:
iphone 3g screen back light lxa786 iPhone, iPad, iPod Hardware Repair 17 03-09-2011 17:25
Iphone no light solution mamun_iqbal2000 iPhone 2 / iPhone 3G / iPhone 3GS 1 01-18-2010 16:31
back light problem in Iphone askaralikp iPhone 2 / iPhone 3G / iPhone 3GS 1 11-15-2009 12:07
1110 back light any solutions? abeesh Nokia Digital Core Technology 4 ( DCT-4 ) 1 06-02-2006 15:47
any solution about back light for ot511 freemobil BF, BG, TH, BHx Series 1 01-30-2005 10:15
Page generated in 0.24712 seconds with 9 queries
