02-22-2012, 15:02 | #901 (permalink) | |
Insane Poster Join Date: Sep 2011
Member: 1654366 Status: Offline Thanks Meter: 0 | Quote:
Yes my friend do it! Far as i undestand for this issue, is that main menu is in short. In my case my home bottom was broken. Always starts on recovery mode when docks was plug in. Thanks a lot, bro. Keep up the good work like always. | |
03-01-2012, 20:03 | #902 (permalink) |
Member: 1654366 Status: Offline Thanks Meter: 0 | Hi Bro Hope you good! Need some help with 3GS logic. So the logic stucks in recovery mode. I had remove the varistors on near power connector. Started from DZ9 no luck. Then i try to remove all varistors... steel the some problem stucks in recovery mode. Trying after with custom firmware 5.0.1 nothing... Trying also with redsn0w to jailbreak to see what pass on screen .. give msg please wait and stay there... Do you have any idea what wrong with it? Maybe nand flash? Thank you very much Kit0 |
03-01-2012, 21:02 | #903 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Moldova,Chisinau. Age: 38
Member: 1017374 Status: Offline Thanks Meter: 2,595 | Quote:
03-02-2012, 13:53 | #905 (permalink) |
Member: 1017374 Status: Offline Thanks Meter: 2,595 | If it fail in any way to restore i m afraid phone is dropped,problem might be at mass memory flash or serial flash ic near cpu need reball one by one. |
03-04-2012, 22:17 | #906 (permalink) |
Junior Member Join Date: Jul 2011 Location: Auckland
Member: 1616305 Status: Offline Sonork: what is this ? Thanks Meter: 0 | iphpne 4s sim card reader fried not reading sim. changed several sim and even swap the the pcb board but same problem persist. simcard reader issue , can any one help me pls . |
03-07-2012, 20:03 | #908 (permalink) |
Junior Member Join Date: Mar 2012
Member: 1729880 Status: Offline Thanks Meter: 0 | Hi have iphone 3gs dead: been dropped voltage taken without charger image voltage checkin here by Wites BBvsd1: 0V vddsd1: 3.7V vddsd2: 3.7V vdsd2: 0V pmic L9AP : 3.7V pmic L10AP: 2.8V one side .. other side 0V sdram: 0v Lcd coil L6AP: 3.7V L4RF: 0v All right thanks in advance for your help.. |
03-07-2012, 20:42 | #909 (permalink) | |
Is this check after you pressed power on??? | |
03-08-2012, 13:14 | #912 (permalink) | |
Some coils output voltage after power button is pressed,Light coil and L9_AP charging coil output voltage after battery is connected. Tell me readings after power button is pressed to see if voltage is supplied to CPU,RAM,Mass Memory,BB CPU,BB Flash etc. In most cases if some voltage is missing or less replace that coil that is output of that missing voltage if not solve reball replace PMIC. | |
03-09-2012, 18:38 | #913 (permalink) |
Member: 1729880 Status: Offline Thanks Meter: 0 | IPHONE 3gs 16gb dead no apparent reason Client decided not to pursue anymore the repair. Anyhow got another..my own cell just died out of the blue Iphone 3gs 16gb. Stop working for apparent no reason. see pic here -No other voltage present anywhere else. -Battery shows 3.7V without the board. -The fuse in green tests ok. Any suggestion ? Sincerely Pat |
03-10-2012, 16:04 | #915 (permalink) | |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
