06-17-2014, 20:12 | #4816 (permalink) |
Junior Member Join Date: Jun 2014
Member: 2206577 Status: Offline Thanks Meter: 0 | It was only after that something weird happened, due to how much I kept opening and closing the iphone up, and removing the battery and re-applying in the process. I believe I may have damaged the battery connector terminal on the motherboard. What is happening now is that you need to pop in a fresh battery that was from another iPhone. Else it will go through a bootloop and never start up, I believe this is because of battery drain. When the new battery is in, the battery percentage is very wrong and resets don't fix it. A few hours later, and the battery will die, and the phone won't turn on unless you put a freshly charged battery in again. The battery terminal connector 'looks' fine, but I believe something pulled off. I have a solder station etc. Would I be able to just resolder and solder the connection? I know about how the solder pads and internal copper wiring work a bit, and do realize that I may be only soldering the pad and not the internal wiring and thus it may still not work. Can anyone give me instructions on how I would test the voltage to make sure, and which prong is most likely the broken on? I'm a complete idiot with a Multi Meter and barely know what goes where unless the instructions are very specific. Any help is much appreciated. And yes, I know of the last ditch effort of compressing the battery connector terminal with another item, but that is a last ditch effort of course. Thank you guys very much. The Issue: Iphone bootloops and turns off every few minutes and reboots. I've also read through this thread titled iphone 4 battery connector on this forum. I can't link it yet. And see the schematic, if I do that with a jumper, will it work? |
06-19-2014, 15:45 | #4820 (permalink) | |
Junior Member Join Date: May 2013 Location: on the Internet
Member: 1928915 Status: Offline Thanks Meter: 1 | Quote:
it still doesnt work. whats PCB? when i search for network manually i get signal but wont let me select keeps showing no service. | |
06-21-2014, 10:20 | #4821 (permalink) | |
Junior Member Join Date: Aug 2012
Member: 1793611 Status: Offline Thanks Meter: 0 | did u got any solution ....???? i have the same problem Quote:
06-21-2014, 14:47 | #4822 (permalink) |
Junior Member Join Date: Apr 2014 Location: Italy
Member: 2167484 Status: Offline Sonork: Can you help me? Thanks Meter: 3 | Good evening, I tunes see the terminal but it always sound as Wen I connect to power. I change battery. The U 5 is very hot ( A3 Angelina??? ) an perhasps U101( I don't dissold the plate) Thank-you |
06-23-2014, 16:13 | #4823 (permalink) |
Junior Member Join Date: May 2009 Location: Italy
Member: 1030071 Status: Offline Thanks Meter: 1 | I have a iphone 5 after liquid has entered the display with black lines and the touch is not working. I have tried to fix the slopes of the connectors but it does not work. Maybe if someone could tell where I have to check to solve the problem. Thanks in advance |
The Following User Says Thank You to dasilvafelix For This Useful Post: |
06-25-2014, 01:34 | #4824 (permalink) |
Junior Member Join Date: Nov 2010
Member: 1433903 Status: Offline Thanks Meter: 0 | i need urgent help please' re iphone 3gs not charging hi all not been on here for a while' but im glad i came to the right place. my problem is iphone 3gs' plug the lead in the laptop a apple lead and the red battery symbol shows some charge' the plug lead icon goes away' and the lighting bolt icon stays on, so it looks like its on charge but it stays the same. when you plug it in the laptop theres no sound like before and itunes dont start automaticly. normaly i say chuck it but its my wifes' and she loves her phone' and dont want a new one, so i have been trying my best to sort this out for her. i bet one of you guys know the answer to this real headache. any help please and thanks in advance. ive got spares i can use if needed. many thanks basicbri |
06-25-2014, 07:56 | #4825 (permalink) |
Junior Member Join Date: Jun 2012
Member: 1775520 Status: Offline Thanks Meter: 1 | heating issues My iPhone 5s 32 GB gets heated a lot while charging. Even if i switch it off and charge. The battery drains from 100% to 0 in 3 Hours. I have tried changing battery ,restoring .. but nothing worked. cant give it to apple store as its from usa and i am out now. Let me know how can i fix it. |
06-25-2014, 10:24 | #4826 (permalink) |
Crazy Poster Join Date: Jun 2009 Location: kathmandu
Member: 1054079 Status: Offline Sonork: 100.1638137 Thanks Meter: 3 | my iphone 3gs has two problem. one is power button not working second one is insert sim but sometime it shows sim but there is no service. please help to solve these problems. thank you. |
06-25-2014, 22:35 | #4827 (permalink) |
Junior Member Join Date: May 2010
Member: 1309096 Status: Offline Thanks Meter: 2 | iPhone 3gs heat Iphone 3gs sudden dead. It heats almost instantly when i connect cable in this area and does not start any more please help free image host |
06-28-2014, 18:00 | #4830 (permalink) | |
Junior Member Join Date: Jul 2011
Member: 1621804 Status: Offline Thanks Meter: 8 | Quote:
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
