Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 07-25-2017, 08:51   #6136 (permalink)
HDccam's Avatar
Member: 1732818
Thanks Meter: 532
Originally Posted by Suzain View Post
Hi i have iphon6plus i replaced touch ic now touch ic is working good but now no sound in call apeaker option showing hide in call and no proximity sensor so i checkd all track and rsistr i puted all jump but problen is still sem plz me thank you.
Sent from my SM-J700F using Tapatalk
For No prox, also check Q1101 if missing or out of place.
For No sound, reball the audio ic.
Next time, Use 340 degrees celcius and flux.
To work with Lower temperature will take longer, but will will lower the risk of overheating other ic's
Old 07-26-2017, 11:23   #6137 (permalink)
Member: 392182
Thanks Meter: 4
i have iphone 5s sometime coming on sometime not on what is problem phone stil new what is problem sir please help me
Old 07-26-2017, 12:58   #6138 (permalink)
Member: 2681768
Thanks Meter: 30
Hello, 6 after lcd replacement boot on apple logo after black screen and 5-10sec later shutdown.
Stuck at 0.2amp when power on.
No water damage.
(other lcd tested same, other batterie same) i can't enter in dfu mode.
someone have idea ?
Old 07-27-2017, 06:41   #6139 (permalink)
Member: 2738648
Sonork: jzhon
Hi!
I have an iphone 6g the problem is the sound is not working, i already tried to replace the speaker but i have the same result. i also tried to change the connector flex but still it doesn't work. can anybody help me..??
Old 07-28-2017, 11:00   #6140 (permalink)
Member: 524618
Hi i have Iphone 6 plus after work 1 or 2 hour restarting phone , en not working earphon and mic , restart power of and home butons , work normaly , 1, 2 hour plss help
Old 07-30-2017, 07:56   #6141 (permalink)
Member: 2741179
hi sir . I have a ipad 4 it has charge problem . I also change u2 ic bath charge not solve any solution
Old 08-01-2017, 00:37   #6142 (permalink)
HDccam's Avatar
Member: 1732818
Thanks Meter: 532
Check caps around your 1608A1 charging ic, if you get 5v when charger is connected. If not, Then replace docking flex
Old 08-01-2017, 00:44   #6143 (permalink)
HDccam's Avatar
Member: 1732818
Thanks Meter: 532
Originally Posted by jzhon View Post
Hi!
Check with volume buttons if your phone is not on always headphone mode. Check also if you have sound with headphone. Remove c1816, dz1813, dz1814 to remove always headphone mode. your speaker work again
The Following User Says Thank You to HDccam For This Useful Post:
Old 08-01-2017, 00:46   #6144 (permalink)
HDccam's Avatar
Member: 1732818
Thanks Meter: 532
No water damage.
someone have idea ?
This happens when your front flex cable is damaged. Try without front camera flex cable connected if your phone will stay stable. Replace the cable.
Old 08-01-2017, 00:48   #6145 (permalink)
HDccam's Avatar
Member: 1732818
Thanks Meter: 532
If its new, then you still have warranty. I advice you to go back to the store.
Old 08-01-2017, 19:32   #6146 (permalink)
Member: 2583349
Hello everyone. I need you help. I have problem with iphone 6 Water damage. The IC as shown in photo is shorted It getting hot. I replaced this IC two times. I don't even know what this IC is. Please help me. I am unable to post photo this is written on IC 48A1KRI .. It down of the tristar
Thank you.
Old 08-02-2017, 13:01   #6147 (permalink)
Member: 2583697
Sonork: 100.1677424
Thanks Meter: 21
IPhone 6 and up Mobel's don't use more than 300 degrees temperatures.
It will damage the other components on that pcb.
Sent from my iPhone using Tapatalk
Old 08-02-2017, 13:02   #6148 (permalink)
Member: 2583697
Sonork: 100.1677424
Thanks Meter: 21
And always covers nearby components where you are working
Old 08-10-2017, 18:35   #6149 (permalink)
Member: 2746196
Ipad 2 stuck in Icloud activation Don't have the Id and password as I'm the second owner how to get rid of it ?
Old 08-10-2017, 18:48   #6150 (permalink)
Member: 2236331
Thanks Meter: 36
iphone 6+s error 9 .... plz tel me solution... i also chane bettry. @ lcd but pronlem stell... plz help me
All Blackberry Hardware and Software Solution youssef01 BlackBerry (RIM) 34 11-01-2012 17:31
I need DVD player hardware and software solution site ..::MOBILES::.. GSM Mobile Links 0 04-05-2009 15:49
O2 Hardware and Software solutions Eagle7 Various 2 04-14-2006 12:47
Page generated in 0.20407 seconds with 10 queries
