Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 01-28-2012, 06:47   #16 (permalink)
Member: 289990
Thanks Meter: 147
3G Component Placing
The Following 5 Users Say Thank You to erric For This Useful Post:
Old 02-22-2012, 15:00   #17 (permalink)
Member: 289990
Thanks Meter: 147
iPhone_4_full_shem_component_placing
The Following 15 Users Say Thank You to erric For This Useful Post:
Old 02-24-2012, 16:43   #18 (permalink)
Member: 1176031
Thanks Meter: 62
Hi Guys,
Don't know whether this is important for you or not but just met these images the other day on the net. Attached are two images of the iPhone 4 logicboard bare (no IC attached to it) just solder pads only. So in case you need to remove an IC from the board you may check before how does the pads look like.
The Following 5 Users Say Thank You to limespirit For This Useful Post:
Old 03-27-2012, 13:26   #19 (permalink)
Wites OM Tesla's Avatar
Member: 1017374
Thanks Meter: 2,594
Exclamation iPhone 4 Have Ten Layers of circuit.
Did you know about this?
The Following 6 Users Say Thank You to Wites OM Tesla For This Useful Post:
Old 04-04-2012, 10:02   #20 (permalink)
Member: 1017374
Thanks Meter: 2,594
Originally Posted by spermcell View Post
mr. wites pls help me w/ my ipod touch 1G ,no back light,
1.Replace flex from board to lcd if same look in picture.
Check component in green mark if all ok.
Replace coil if same then ic.
Be careful when open small board it is made very bad that flex can broke if moved too much.
The Following 3 Users Say Thank You to Wites OM Tesla For This Useful Post:
Old 05-16-2012, 12:17   #21 (permalink)
Member: 289990
Thanks Meter: 147
Full schematic for iPhone 4S
The Following 23 Users Say Thank You to erric For This Useful Post:
Old 08-01-2012, 10:21   #22 (permalink)
Member: 289990
Thanks Meter: 147
iPad 2 full schematic
The Following 34 Users Say Thank You to erric For This Useful Post:
Old 08-01-2012, 10:25   #23 (permalink)
Member: 289990
Thanks Meter: 147
ipad 1 full schematic
The Following 35 Users Say Thank You to erric For This Useful Post:
Old 09-18-2012, 13:21   #24 (permalink)
Member: 1176031
Thanks Meter: 62
iPhone 3GS, 4, 4S, iPad1, 2 NAND Flash Pinouts
Attached is an image of the pinouts of the NAND Flash for most of the devices from Apple.
The Following 7 Users Say Thank You to limespirit For This Useful Post:
Old 12-25-2012, 12:55   #25 (permalink)
Cheater -Don't Deal with him-
Member: 644786
Thanks Meter: 2,166
Thumbs up Visual/Mechanical Inspection Guide for iPhone 5
Apple provides service for iPhone products with defects in materials and workmanship under the iPhone
warranty or applicable consumer law. This document helps you identify conditions that affect whether Apple
covers service.
NOTE: This document applies to iPhone 5 only.
Apple warrants iPhone against defects in materials and workmanship when used normally in accordance with
Apple’s published guidelines for a period of ONE (1) YEAR from the date of original retail purchase by the enduser
purchaser. The iPhone warranty covers failures caused solely by manufacturing defects, regardless of
accidental damage. The warranty does not apply to cosmetic damage, including but not limited to scratches,
dents and broken plastic on ports or to defects caused by normal wear and tear or otherwise due to the normal
aging of the device.
Benefits under the manufacturer's warranty are in addition to rights provided by consumer law. For details,
refer to Apple - Additional Legal Rights for Consumers.
Purpose of Visual/Mechanical Inspection
The Visual/Mechanical Inspection (VMI) will help you determine whether a user's described issue with the
iPhone was caused by a defect in materials and workmanship, accidental damage or an unauthorized
modification, and then determine which service type to use. Defects in materials and workmanship are
eligible for service under Apple's Limited Warranty or applicable consumer law. Some forms of accidental
damage may be eligible for service under an Apple Protection Plan (APP) or AppleCare+ (where available) or
for out-of-warranty service at a cost to the user.
Service Eligibility
■ Eligible Damage: Damage caused by defects in materials or workmanship and some forms of
accidental damage, for example liquid contact. See Guidelines for Damage Classification and Reference
Photos (page 8) for examples of damage that is eligible for service under Apple's limited warranty,
AppleCare Protection Plan, AppleCare + (where available) or applicable consumer law or for out-ofwarranty
■ Ineligible Damage: Severe or catastrophic damage caused by accident, abuse, disassembly or
unauthorized service or modification is ineligible for service under Apple's Limited Warranty or for outof-
warranty service. See Guidelines for Damage Classification and Reference Photos (page 8) for
examples of damage that is ineligible for service. Devices with this type of damage should be returned
to the user un-repaired.
Note: Catastrophic damage may be covered for AppleCare+ users in certain countries. Refer to Apple
Support article OP691: Coverage eligibility for products covered by AppleCare+ for more information.
070-3037-C_EN.pdf
The Following 3 Users Say Thank You to SEMCSEC For This Useful Post:
Old 01-30-2014, 14:22   #26 (permalink)
Member: 1017374
Thanks Meter: 2,594
Originally Posted by cqljohn View Post
Wites, are you for real on you have a copy of the CDMA iPhone 4 version? I have a couple I am trying to repair for some customers but trying to trace the circuits through the GSM version sux. I would pay on your site if these are available there.
Yes i have it i not share on my site but is enough to register then private message me your mail i will send here pic.
Also i have solutions for it.
The Following 2 Users Say Thank You to Wites OM Tesla For This Useful Post:
Old 05-29-2014, 12:59   #27 (permalink)
Member: 2167733
Thanks Meter: 5
Since I cannot find the edit button. Please do not PM me anymore, instead just use this mega link. Thanks
h t t p : / / b i t . l y / 1 r j M 9 V v
Remove spaces, blame inconvenience on me not being able to post proper links.
password is gsm-forum
The Following User Says Thank You to VA6DAH For This Useful Post:
Old 10-11-2014, 02:20   #28 (permalink)
Member: 2220270
Thanks Meter: 8
crupted zip file
if u have ok please share...
Old 10-18-2014, 17:58   #29 (permalink)
Member: 420244
Thanks Meter: 41
hi guys pls i need ipad a1430 schematic or if any one can tell me were is located R1204 resistor
thks in advance
Old 12-28-2014, 09:38   #30 (permalink)
Member: 1212320
Thanks Meter: 46
hi
pleas i need iphone 6 / 6+ schematics
The Following 2 Users Say Thank You to mxkey lover For This Useful Post:
I have Wintesla PKD-1 dongle schematic and activation file Gsmhq Nokia Hardware & Hardware Repair 3 08-20-2004 10:11
Fbus/Mbus schematics? Blunty Nokia Hardware & Hardware Repair 3 06-03-2001 01:59
Si-prog schematics, some one help AMTX99 Nokia Hardware & Hardware Repair 4 09-21-2000 23:21
looking schematic for nokia5161 battery with vibra dofie Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-13-2000 22:48
GSM Links Datacable Schematic Logo Ringtone GM GSM Mobile Links 0 01-30-2000 14:52
Page generated in 0.30861 seconds with 10 queries
