05-06-2017, 14:10 | #1 (permalink) |
Junior Member Join Date: Apr 2017
Member: 2711169 Status: Offline Thanks Meter: 0 | Itunes error 4013, Iphone 5s [12:59:13.0971] Changing state from 'Restoring' to 'Transitioning' [12:59:13.0971] Creating timer to monitor transition [12:59:13.0971] Creating a timer for 10 minutes [12:59:26.0400] Recovery mode device connected [12:59:26.0400] Transitioning device returned, continuing restore. [12:59:26.0400] Canceling timer [12:59:26.0400] Restore completed, status:4013 [12:59:26.0400] Failure Description: [12:59:26.0400] Depth:0 Code:4013 Error:Unexpected device state 'Recovery' expected 'RestoreOS' [12:59:26.0400] Changing state from 'Transitioning' to 'Restoring' [12:59:26.0400] State Machine Dump, status:ERROR - [state:Recovery remaining-cycles:0] -> [state:RestoreOS remaining-cycles:1 (current state)] [12:59:26.0400] Unexpected device state 'Recovery' expected 'RestoreOS' [12:59:26.0400] Changing state from 'Restoring' to 'Error' [12:59:26.0400] State is now set to error Does anyone already solved this ? Any suggestions are appreciate. Many thanks |
05-24-2017, 11:47 | #3 (permalink) |
Moderator Join Date: Oct 2006 Location: Tunisia Age: 41
Member: 363451 Status: Offline Sonork: 100.1577895 Thanks Meter: 834 | Error 4013 : Connection to device is lost after the "Preparing iPhone for Restore" step but before the phone is actually wiped causing it to boot normally. Check USB connections and try again. Check battery and power way. Finally check nand ic, re-hot it would be work.
__________________ Regards, Mehdi |
The Following 2 Users Say Thank You to loca|host For This Useful Post: |
07-08-2017, 03:34 | #6 (permalink) | |
Junior Member Join Date: Jul 2010
Member: 1340458 Status: Offline Thanks Meter: 0 | Quote:
and did the u2_rf or u1_rf cant take a enough power because it error 48 occurs hoiw i know if u2 rf is recieved power did any input or test pont and to u1_rf?? | |
10-08-2018, 08:53 | #7 (permalink) | |
Junior Member Join Date: Aug 2018 Location: new york
Member: 2861348 Status: Offline Thanks Meter: 4 | fix iTunes error 4013 Quote:
