06-14-2020, 15:54 | #1 (permalink) |
Junior Member Join Date: Mar 2010
Member: 1253358 Status: Offline Thanks Meter: 2 | Naviplus pro3000s upgrade nand problem I am having problem upgrading Nand storage for my ipad air 2 16gb I am using naviplus pro3000s with the latest firmware i can find(v1.1309_20190315-with hhd fix) The steps i usually use: 1)format new nand 2)read original nand 3)write original nand info onto the new nand Now i have tried 2 different 32gb nand but keep getting 11% failure at entering recovery mode(Ipad on DFU mode and using 3utools) Ipad can restore fine once i put back on the original Nand Anyone has same issue?is it firmware problem? |
The Following User Says Thank You to morbid80 For This Useful Post: |
06-16-2020, 12:11 | #2 (permalink) |
Freak Poster Join Date: May 2013 Location: Netherlands
Member: 1939450 Status: Offline Thanks Meter: 165 | No still got the problem. Waiting for Purple to be compatible with air 1/2 to check if this can adjust syscf correctly. Guess that itunes implemented an parts SN check. (because if you write bottom info with naviplus, always camera SN etc is the same) And only sn/wf/bt is changed. So maybe itunes now checkes if this applies and kicks out the restore? |
07-09-2020, 19:49 | #3 (permalink) | |
Freak Poster Join Date: Oct 2014
Member: 2277735 Status: Offline Thanks Meter: 215 | Quote:
12-09-2021, 01:59 | #5 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Abidjan,ivory coast
Member: 1272267 Status: Offline Sonork: 100.1667652 Thanks Meter: 408 | J’ai un problème pour corriger les erreurs 4013 avec la version v1.1310 parce que j’ai pas HDD Fix mais plutôt Other Fix aider moi svp |
