08-07-2012, 05:43 | #34 (permalink) |
Junior Member Join Date: May 2012
Member: 1757762 Status: Offline Thanks Meter: 0 | I have replaced the blacklight diode and the filter. Now the blacklight diode have 3.95v on both leg and the filter have continuity and 3.95v on both leg also. Still no backlight. Wites said I need to have 4.7v. on both leg, but I only have 3.95v. Could this be the problem. The only thing I haven't changed is the 4r7 coil. I don't think the coil is bad since it have continuity. What else could be wrong? |
08-07-2012, 07:19 | #35 (permalink) | |
Banned Join Date: Mar 2012
Member: 1738165 Status: Offline Thanks Meter: 206 | Quote:
same logic that's why you can just jump a coil. must replace and get the inductance going. continuity means very little in this case. | |
08-07-2012, 09:00 | #36 (permalink) | |
Member: 1757762 Status: Offline Thanks Meter: 0 | Quote:
08-07-2012, 09:55 | #37 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Moldova,Chisinau. Age: 38
Member: 1017374 Status: Offline Thanks Meter: 2,594 | Quote:
08-07-2012, 21:47 | #38 (permalink) | |
I use a hot tweezers to remove the diode and filter, but I used a soldering iron to solder the the new diode and filter. I carefully checked the diode and filter solder joints under 30x power magnifier loupe and were not able to detect any cracks. The joints were solid and clean. What I don't understand was how come I have 3.95v on both legs instead of 4.7v? Last edited by fs2787; 08-07-2012 at 21:55. | |
08-07-2012, 21:52 | #39 (permalink) | |
08-08-2012, 07:07 | #40 (permalink) |
Member: 1757762 Status: Offline Thanks Meter: 0 | I replaced the 4r7 coil, still no backlight . Now the voltage shows 4.15v instead of 4.95v. What else could be wrong? I was wondering if there is a cold solder joint somewhere. Should I go ahead and reflow the logic board? |
08-08-2012, 09:42 | #41 (permalink) | |
No friend no reheat in my hardware solution first step is connector an resolder 2 yellow marked pins,this solution is if you try other lcd with flex. | |
08-08-2012, 17:28 | #42 (permalink) | |
I am not sure if I understood your answer. Do you mean try using another flex cable and another LCD screen, if this doesn’t work make a jump from the filter to one of the pin on the LCD connector like in the picture above. Last edited by fs2787; 08-08-2012 at 17:34. | |
08-08-2012, 17:57 | #43 (permalink) | |
which side did you change the backlight chip its a diode it does have polarity the lines side have to point down. and are you sure the soldering with the filter is successful? | |
08-08-2012, 19:37 | #44 (permalink) |
Member: 1757762 Status: Offline Thanks Meter: 0 | Yes, I make sure the polarity on the diode is correct. Solder the filter was relatively a simple task under 5x magnification. Like I said before I examined both the diode and filter under 30x magnification and both are clean and solid. The only thing I haven't done is replacing the flex LCD cable. I knew for sure that the diode was bad, but I think the filter and coil were good. I went ahead and replaced all of them to be sure since I bought the complete backlight replacement kit. Still no backlight! |
08-08-2012, 20:51 | #45 (permalink) | |
ok friend next step but i would do this first resolder connectors not only on board but on lcd itself if still same try other lcd for test only. | |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
