12-09-2016, 06:38 | #1 (permalink) |
Freak Poster Join Date: Dec 2010
Member: 1481974 Status: Offline Thanks Meter: 42 | iPhone 6 intermittent network Tristar was bad (would only charge when turned off) And network sometimes it would work sometimes it wouldn't. It sometimes works if I reset all settings. Sometimes it works if I restart the phone but sometimes it says searching or no network. I replaced the tristar and corrected the charging issue but I still have the intermittent network issue. What should I check? I've been seeing a few people having baseband ic issues but I do have imei number showing up. |
12-09-2016, 08:25 | #4 (permalink) |
Member: 1481974 Status: Offline Thanks Meter: 42 | I'll check it tomorrow but no I don't think this one has antenna ways issues. It catches reception no problem full bars when it works. Something must be wrong with baseband or poweramps I'd imagine just need some help pointing out exactly where the issue could be. I'll check imei when it gets no service as well. Thanks |
12-09-2016, 19:17 | #5 (permalink) |
Member: 1481974 Status: Offline Thanks Meter: 42 | OK so right now its on searching and I tried typing the *#06# and nothing happens. If I go to the settings I could see IMEI but typing it on the phone app it just stays there |
12-10-2016, 01:50 | #6 (permalink) |
Freak Poster Join Date: Dec 2016
Member: 2656737 Status: Offline Thanks Meter: 12 | It's baseband problem you have no imei so try to check baseband voltages around U_PMICRF on these capacitors C3208_RF, C3202_RF,C3210_RF, C3211_RF, C3213_RF, C3209_RF, C3212_RF if some voltages are missing look for short at the same line or replace U_PMICRF. if all voltages are present try to reball Baseband CPU must have some broken pads under it. |
