05-28-2011, 20:06 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: root
Member: 111871 Status: Offline Sonork: 100.78975 Thanks Meter: 100 | comeŽon... another defective riffbox??? wtf! Connecting to the dead body... ERROR: Set I/O Voltage to 2,60V failed. Real reading is 2,72V took long before some supporter tell that hardware was really damaged, and then I bought another riffbox. this one, works flawlessly, but a customer offered me a good money for it, and I sold it, and then bought a new one, it arrived last week, and today I finally had the time to mess with my dead sams/htc, what do I get? Connecting to the dead body... ERROR: Set I/O Voltage to 2,60V failed. Real reading is 2,86V What I want, is a way to fix those boxes, or, at least some information to know where I should look for the problem. The reseller (ipmart) only tells to sendŽem at my cost (fedex br-> my + my->br = +/- 140usd) which is more expensive than the box itself, and would take long, while the phones that need to be ressurected are right in front of me. Do you consider normal any user have this kind of issue 2 out of 3 times? Whoever makes that hardware should at least make a simple test on the boards to make sure they work before sellingŽem. As quality test of the hardware isnŽt a real concern, helping users to fix their brand new defective product should be. Before taking the p1ss on me, just remember: If my boxes got here as they should, this thread wouldnŽt exist. I just wantŽem working, and nothing else. So, where in the board should I start looking for hw problems? br |
05-28-2011, 23:03 | #4 (permalink) |
Member: 111871 Status: Offline Sonork: 100.78975 Thanks Meter: 100 | to be 100% sure problem is the box, got a riff lended from a friend. just switched my riff with his and... Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.24, JTAG Manager Version: 1.32 Selected Resurrector: [Samsung I9000] Connecting to the dead body...OK Detected dead body ID: 0x1BA00477 - CORRECT! Set I/O Voltage reads as 2.84V, TCK Frequency is 2 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip ID: 0x00EC/0x0050 (512MB) Flashing the dead body...OK Resurrection complete! and i5700... Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.24, JTAG Manager Version: 1.32 Selected Resurrector: [Samsung I5700 PDA] Connecting to the dead body...OK Detected dead body ID: 0x07B76F0F - CORRECT! Set I/O Voltage reads as 2.66V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip ID: 0x00EC/0x0058 (512MB) Flashing the dead body...OK Resurrection complete! --------------------------------------------------------------- now i5700 using my box: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.24, JTAG Manager Version: 1.32 Selected Resurrector: [Samsung I5700 PDA] Connecting to the dead body...ERROR ERROR: The RTCK Signal does not respond. Connecting to the dead body... ERROR: Set I/O Voltage to 2,60V failed. Real reading is 2,86V Connecting to the dead body... ERROR: Set I/O Voltage to 2,60V failed. Real reading is 2,89V Connecting to the dead body... ERROR: Set I/O Voltage to 2,60V failed. Real reading is 2,78V Connecting to the dead body... ERROR: Set I/O Voltage to 2,60V failed. Real reading is 2,83V it also lacks rj45 4.2v as well (0,02v). |
05-29-2011, 08:55 | #6 (permalink) |
Freak Poster Join Date: Apr 2009
Member: 1012476 Status: Offline Sonork: 100.1592602 / 100.1650362 Thanks Meter: 20 | If there is where we start the sw will run selftest on box .!! So that user will be understand is the box fail..or not. Hope programmer will give better clear answer easy for user |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
