Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > RIFF Box Team > RIFFBOX
Old 06-18-2013, 12:43   #1 (permalink)
Member: 1754412
Sonork: 100.1620116
Thanks Meter: 27
galaxy s3 I747 error from samsung warranty
hi
i have four motherboards I747, all came from Samsung after the customer refuse the repair cost (void warranty with flashed custom rom or firmware). for sure there are not bricked forever while Samsung can fix if the client pay.
any idea?
Open serial port...OK
Connecting to the RIFF Box...OK
Firmware Version: 1.35, JTAG Manager Version: 1.49
Selected Resurrector: [Samsung I747M V1.0.4711.52503]
Restarting target (nRST Low then High)...OK
Connecting to the dead body...OK
Detected dead body ID: 0x706B50E1 - CORRECT!
Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK
Adaptive Clocking RTCK Sampling is: [Sample at 2 MHz]
Resurrection sequence started.
Establish communication with the phone...OK
Initializing internal hardware configuration...OK
Uploading resurrector data into memory...OK
Starting communication with resurrector...FAILED
ERROR: No response from the RIFF Bo
x.
thanks
The Following User Says Thank You to nickmatine For This Useful Post:
Old 06-18-2013, 14:14   #2 (permalink)
.::TEJARAM::.'s Avatar
Member: 1681461
Sonork: [OFFLINE]
Thanks Meter: 1,011
HI
RIFF JTAG Box FAQ - ERROR: No response from the RIFF Box.
BR, TEJARAM
Old 06-18-2013, 18:14   #3 (permalink)
Member: 1754412
Sonork: 100.1620116
Thanks Meter: 27
thanks for reply
i read faq before
i have a custom connection, no solder needed and have tried also with working motherboards
tried all rtck speed
maybe this one Check device hardware for problems
but like i said if customer pay they can fix it
so it should be a trick
Old 06-18-2013, 22:43   #4 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
Hi
I747 based on Qualcomm....And Usually Need Check HW
Please Check This:
1-PC Detected Phone in "QUHSB " Mode????
2-Please Check Phone History With Your Client
if phone dead suddenly it's HW Problem
if phone dead by Wrong SW,You Can Repair Via JTAG(RIFF-BOX)
I Think I have Officially SD Boot Repair For I747....(I Need Check My PC in Office)
So,Plz Contact Me Via Sonork
Thanks
The Following 2 Users Say Thank You to BABAK NURI For This Useful Post:
Old 06-18-2013, 22:55   #5 (permalink)
Member: 1754412
Sonork: 100.1620116
Thanks Meter: 27
Originally Posted by BABAK NURI View Post
Hi
Please Check This:
Thanks
i will contact you via sonork
all motherboards SW problem, all bad firmware flashed or bad custom recovery
and all comes from samsung
all with same errro with jtag and all from samsung
Old 06-18-2013, 23:12   #6 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
Hi
Ok,Please Find Another Working Phone For Make SD_Boot Recovery
Then,Contact Me Tomorrow ,i'll Send You Boot_Recovery
Can You Check PCB For Exactly Printed Model? May be You have I747m ????
The Following User Says Thank You to BABAK NURI For This Useful Post:
Old 06-18-2013, 23:52   #7 (permalink)
LEENO's Avatar
Member: 38084
Thanks Meter: 115
i have riffbox, can i hav too sd_boot recovery? I have working i9300, have it the same cpu?
Old 06-19-2013, 03:35   #8 (permalink)
spagman's Avatar
Member: 1783314
Sonork: 100.1620532
Thanks Meter: 127
Originally Posted by nickmatine View Post
hi
any idea?
x.
thanks
Why are you using I747M dll if the motherboards are I747 ?
Old 06-19-2013, 11:24   #9 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
Hi
Sure,If You Want I747 Boot_Recovery,You Can Contact Me Via Sonork,i'll Give You
No,It's Not Same,i9300 is Exynos and I747 is Qualcomm
The Following 3 Users Say Thank You to BABAK NURI For This Useful Post:
Old 06-19-2013, 13:33   #10 (permalink)
Member: 1754412
Sonork: 100.1620116
Thanks Meter: 27
it's I747m
all are i747M
i have another i747m working
Old 06-19-2013, 13:35   #11 (permalink)
Member: 1754412
Sonork: 100.1620116
Thanks Meter: 27
all motherboards are i747m
Old 06-19-2013, 14:39   #12 (permalink)
Member: 1353936
Thanks Meter: 7
Hi
I need I747 Boot_recovery too.
Thanks.
Old 06-20-2013, 03:28   #13 (permalink)
Member: 1160572
i have exact same problem...is it possible that they disabled jtag mode?
Old 06-20-2013, 11:20   #14 (permalink)
Member: 1754412
Sonork: 100.1620116
Thanks Meter: 27
Yes. Maybe it's possible. But they are able to enable also. I don't know how
Old 06-20-2013, 17:16   #15 (permalink)
Member: 1160572
Ya I know they want to charge my customer $400 to do it....anyways i will try to find the schematics for the phone I think there is a way to re-enable it
Page generated in 0.19220 seconds with 8 queries
