03-02-2013, 12:16 | #1 (permalink) |
Registered User Join Date: Aug 2010 Location: EVERY WHERE Age: 38
Member: 1372393 Status: Offline Sonork: I.M.STORE Thanks Meter: 90 | GOT ERROR WHILE FLASHING SAMSUNG S5830i I GOT THIS ERROR WHILE RESURRECTION.. Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung S5830i V1.0.4476.13359] Restarting target (nRST Low then High)...OK Connecting to the dead body...OK Detected dead body ID: 0x07B3617F - CORRECT! Set I/O Voltage reads as 3.00V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 12 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB) Selected Resurrection Data for the NAND Chip with Page size = 4KB Flashing the dead body... ERROR: DCC Loader has reported Error Code = 0x22 (0x000000). Trying to recover...FAILED ERROR: Failed due to multiple communication errors. Terminating at 0x000000000000 AND WHILE FLASHING ALSO SAME ERROR.... Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung S5830i V1.0.4476.13359] Restarting target (nRST Low then High)...OK Connecting to the dead body...OK Detected dead body ID: 0x07B3617F - CORRECT! Set I/O Voltage reads as 3.00V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 12 MHz] Settings Code: 0x36010011000000000000000020000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB) Writting FLASH1 memory from 0x000000000000 to 0x00001FFFFFFF ERROR: DCC Loader has reported Error Code = 0x22 (0x000000). Trying to recover...FAILED ERROR: Failed due to multiple communication errors. Terminating at 0x00000000000 I CHAEKED IT BY HARD WARE ALSO BOARED IS TOTALY FRESH AND NEW....... CAN ANY ONE GUIDE ME TO SOLVE THIS ERROR... |
03-03-2013, 00:36 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Please Read: RIFF JTAG Box FAQ - ERROR: Failed due to multiple communication errors. But i think you need just press and keep power on key |
03-03-2013, 08:01 | #3 (permalink) | |
Member: 1372393 Status: Offline Sonork: I.M.STORE Thanks Meter: 90 | Quote:
i have tried all my best ......i always got same error......... i just want to repair its boot.......... | |
