GT-I9082 ERROR: Wrong response Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [Samsung I9082 V1.0.4896.5945] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 1.80V, TCK Frequency is 9 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...FAILED ERROR: Wrong response code from the RIFF Box: 0x82 |
I'm waiting for You on Sonork. |
some problem;..... how to solve? jtag manager 1.51 box firmware 1.37 model select: i9082 my phone model : i9082L error 0x82 |
Code: Open serial port...OK |
how to make this cable? http://forum.gsmhosting.com/vbb/9458274-post9.html Legija says it exists but do not teach .... |
Product supporters Where are you please help me its urgent |
0x82 error have a few reason 1-bad soldered jtag wires 2-power not good....,Use power supply 3-use usb cable or usb+jig but, in new BCM if Rom2 erased,we can't access via jtag interface Thanks |
wires soldered station Ok how to know if it's new bcm ROM2? + usb jig? did not understand .... I pay the cable Riff and put in a usb cable original 10cm + or - |
Babak Nuri No reply for me ? |
Mr.legija I have same problem right now. Could you please contact me on my sonrok if you have any idea? |
the same problem and not solved Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Samsung I9082 V1.0.4905.50548] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 1.80V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...FAILED ERROR: Wrong response code from the RIFF Box: 0x82 |
same problem here, Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Samsung I9082 V1.0.4905.50548] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 8 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...FAILED ERROR: Wrong response code from the RIFF Box: 0x82 the only solution after rewriting rom2 we can connect phone via JTAG connection and repair boot |
read this RIFF JTAG Box FAQ - Error code 0x82 |
