04-12-2011, 12:19 | #1 (permalink) |
Junior Member Join Date: Oct 2010
Member: 1417615 Status: Offline Thanks Meter: 0 | help tg01 cant resurrector Connecting to the RIFF Box...OK Firmware Version: 1.21, JTAG Manager Version: 1.29 Selected Resurrector: [Toshiba TG01] Connecting to the dead body...OK Detected dead body ID: 0x202400E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip ID: 0x00FE/0xFEFE Flashing the dead body...OK Resurrection complete! but cant work,cant read fullflash Connecting to the dead body...OK Detected dead body ID: 0x202400E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip ID: 0x00FE/0xFEFE ERROR: Cannot Automatically Determine the Selected FLASH1 Chip's size. Terminating. help! |
04-12-2011, 13:39 | #3 (permalink) |
Member: 1417615 Status: Offline Thanks Meter: 0 | Another Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.21, JTAG Manager Version: 1.29 Selected Resurrector: [Toshiba TG01] Connecting to the dead body...OK Detected dead body ID: 0x202400E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 4 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip ID: 0x00EC/0x55BC (512MB) Writting FLASH1 memory from 0x00000000 to 0x1FFFFFFF WARNING: Programming Error (0x24) at 0x07F40000 is Ignored. WARNING: Programming Error (0x24) at 0x09FE0000 is Ignored. ERROR: Timeout while waiting for DCC Loader response. Trying to recover...OK ERROR: Timeout while waiting for DCC Loader response. Trying to recover...OK ERROR: Timeout while waiting for DCC Loader response. Trying to recover...OK ERROR: Timeout while waiting for DCC Loader response. Trying to recover...OK Completed in 01:07:02.750 (Average Transfer Rate: 134.40 kB/s) same can not work |
04-12-2011, 15:03 | #6 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | WARNING: Programming Error (0x24) at 0x07F40000 is Ignored. WARNING: Programming Error (0x24) at 0x09FE0000 is Ignored. Above errors indicate that NAND chip has bad blocks. Depending if this block contain no data, or it holds something important, phone may work or no. |
04-12-2011, 16:45 | #7 (permalink) |
Member: 1417615 Status: Offline Thanks Meter: 0 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.22, JTAG Manager Version: 1.30 Selected Resurrector: [Toshiba TG01] Connecting to the dead body...OK Detected dead body ID: 0x202400E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...FAILED ERROR: Wrong response code from the RIFF Box: 0x45 |
05-12-2011, 02:08 | #9 (permalink) |
Junior Member Join Date: Aug 2010 Location: CA,USA
Member: 1360305 Status: Offline Sonork: 100.1581432 Thanks Meter: 2 | Legija i have the Same problem 100% i wonder why cant fix this ?! i select HD2 and write dump ok and i flash phone and power ok but phone give always no sim have any idea ? BR |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
