05-07-2011, 17:01 | #1 (permalink) |
Freak Poster Join Date: May 2008 Location: Dubai Age: 35
Member: 771979 Status: Offline Sonork: 100.1676605 Thanks Meter: 55 | HTC Desire after RESURRECT still dead [5/7/2011 8:05:57 AM] [START OPERATION_ID = RESURRECT] [5/7/2011 8:06:42 AM] Open serial port...OK [5/7/2011 8:06:42 AM] Connecting to the RIFF Box...OK [5/7/2011 8:06:42 AM] Firmware Version: 1.23, JTAG Manager Version: 1.29 [5/7/2011 8:06:42 AM] Selected Resurrector: [HTC Desire] [5/7/2011 8:06:42 AM] [5/7/2011 8:06:42 AM] Connecting to the dead body...OK [5/7/2011 8:06:42 AM] Detected dead body ID: 0x202400E1 - CORRECT! [5/7/2011 8:06:42 AM] Set I/O Voltage reads as 3.00V, TCK Frequency is RTCK [5/7/2011 8:06:42 AM] Adaptive Clocking RTCK Sampling is: [Sample at MAX] [5/7/2011 8:06:42 AM] [5/7/2011 8:06:42 AM] Resurrection sequence started. [5/7/2011 8:06:42 AM] Establish communication with the phone...OK [5/7/2011 8:06:42 AM] Initializing internal hardware configuration...OK [5/7/2011 8:06:42 AM] Uploading resurrector data into memory...OK [5/7/2011 8:06:42 AM] Starting communication with resurrector...OK [5/7/2011 8:06:42 AM] [5/7/2011 8:06:42 AM] Detected an Initialized FLASH1 Chip ID: 0x00EC/0x55BC (512MB) [5/7/2011 8:06:42 AM] Selected Resurrection Data for the NAND Chip with Page size = 2KB [5/7/2011 8:06:42 AM] [5/7/2011 8:06:42 AM] Flashing the dead body...OK [5/7/2011 8:06:42 AM] Resurrection complete! [5/7/2011 8:06:42 AM] [FINISH OPERATION_ID = RESURRECT] now when i power on the phone only red and green light blinking. i tryed power on pressing the volum down and power button but no luck |
05-08-2011, 23:04 | #2 (permalink) |
Freak Poster Join Date: Nov 2010 Location: UK
Member: 1454100 Status: Offline Thanks Meter: 28 | set RTCK Sampling to a low setting and try again ! if you set the CID to PB9920000 download ** This ** then rename it to PB99IMG and dump it on the root of your mem card and boot in hboot and away you go |
05-09-2011, 12:07 | #3 (permalink) |
Member: 771979 Status: Offline Sonork: 100.1676605 Thanks Meter: 55 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.23, JTAG Manager Version: 1.32 Selected Resurrector: [HTC Desire] Connecting to the dead body...OK Detected dead body ID: 0x202400E1 - CORRECT! Set I/O Voltage reads as 3.00V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip ID: 0x00EC/0x55BC (512MB) Selected Resurrection Data for the NAND Chip with Page size = 2KB Flashing the dead body...OK Resurrection complete! still same TCK is set to Simple at 1 MHZ but still no luck |
06-11-2011, 17:01 | #5 (permalink) | |
Freak Poster Join Date: Jan 2010
Member: 1209537 Status: Offline Thanks Meter: 22 | Quote:
same problem red and green light blinking. pls hlp me | |
06-11-2011, 18:11 | #6 (permalink) |
Member: 1454100 Status: Offline Thanks Meter: 28 | Put your phone in hboot mode take battery out for 5 seconds then reinsert it and push volume down and power at the same time then follow this if you set the CID to PB9920000 download ** This ** then rename it to PB99IMG and dump it on the root of your mem card Sent from my xxx using Tapatalk |
08-02-2011, 07:56 | #9 (permalink) |
Registered User Join Date: Oct 2010 Location: iran - mazandaran- shahi Age: 41
Member: 1422911 Status: Offline Sonork: i have done but i forget Thanks Meter: 35 | if u reconect the wire of jtag to phone in powering it result in this problem then after resursation reconect jtag wire after that power it |
The Following User Says Thank You to garibaldini For This Useful Post: |
5110/6110 after unlocking see only network to which it was locked and ... | 2M | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 07-25-2000 00:51 |
5110 5.24 locked all 4 locks after unlocking... | MCG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-07-2000 22:24 |
Still with nokia 5110 ver 5.24 | VirtualM | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 11-11-1999 18:57 |
DOES THE CELLNET DIGA HACK STILL WORK??? | SP UNLOCKER 2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-04-1999 13:55 |
"Menu 11"? after Net monitor | Pyron | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 08-09-1999 10:07 |
