07-28-2010, 08:22 | #2 (permalink) |
No Life Poster Join Date: Mar 2002 Location: gsmcity Age: 45
Member: 10505 Status: Offline Sonork: 100.40828 Thanks Meter: 364 | Just press Resurrection button and you will see next: BR levsha |
The Following 6 Users Say Thank You to levsha For This Useful Post: |
07-31-2010, 10:07 | #4 (permalink) |
Member: 10505 Status: Offline Sonork: 100.40828 Thanks Meter: 364 | Always use RTCK clock for stabile work with chips which supports RTCK signal. Change speed settings and post result here. BR levsha |
07-31-2010, 10:25 | #5 (permalink) |
Insane Poster Join Date: Jan 2006
Member: 216062 Status: Offline Thanks Meter: 11 | HD2 Leo repair boot Error. Open serial port...OK Connecting to the RIFF Box...OK Connecting to the dead body...OK Detected dead body ID: 0x202400E1 - CORRECT! Set I/O Voltage reads as 2.62V, TCK Frequency is RTCK Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...FAILED ERROR: Read/Write memory failed during H/W Init. I follow the instructions above error. Why? |
07-31-2010, 10:41 | #6 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | From log i can see that You didnt connected NRST signal. Make sure to connect all 8 points ! Other cause for this error can be unstable power to board. DO NOT use USB Hubs, or Front USB ports on PC. |
07-31-2010, 19:06 | #14 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | And do You know how phone was damaged ? Remember that if eeprom is erased, it will not enter bootloader mode. In that case You also need to repair IMEI blocks, in order to fix security and update eeprom. |
Mega offer : for all nokia lovers ;-) | 666 | Main Sales Section | 1 | 02-01-2002 02:35 |
SMS Prank, thread ??? | micklong | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 01-09-2002 11:38 |
Mega-Guru! Help! 5110 is dead! | ReBoot | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 06-19-2001 21:24 |
HD2 Simlocked!!! | J | Alcatel & TCL Old Models | 0 | 02-06-2000 16:16 |
