huawei c2830 hang on tata logo not connect in riif box huawei c2830 hang on tata logo not connect in riif box whats the problem here is log Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.23, JTAG Manager Version: 1.32 Selected Resurrector: [Huawei C2830] Connecting to the dead body...ERROR Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Model selected: HUAWEI - Huawei C2830 ERROR: The RTCK Signal does not respond. |
i also tried with 2830 but not success in 2 sets 2829 is working properly |
no replay from riff team huawei c2830 not connected with riff box |
Hi, Plz Check Ur Cable Connection,Cable Length and Make Jumper Correctly On PInout .... Pinout Are Tested and Working ;) Wbr lalitg |
i check all connection but same problem The RTCK Signal does not respond. here is log Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.23, JTAG Manager Version: 1.32 Selected Resurrector: [Huawei C2830] Connecting to the dead body...ERROR Set I/O Voltage reads as 1.82V, TCK Frequency is RTCK Model selected: HUAWEI - Huawei C2830 ERROR: The RTCK Signal does not respond. |
i will suggest to change box firmware and try ........may be downgrade it ........ |
choose resurecttor dll QSC1100 during 2830 operation br, |
i try qsc1100 dll also but same error The RTCK Signal does not respond. here is log Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.23, JTAG Manager Version: 1.32 Selected Resurrector: [QSC1100 X14] Connecting to the dead body...ERROR Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Model selected: QUALCOMM (NOR) - QSC1100 X14 ERROR: The RTCK Signal does not respond. |
huawei c2830 connected successfully huawei c2830 connected successfully here is log Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.23, JTAG Manager Version: 1.32 Selected Resurrector: [Huawei C2830] Connecting to the dead body...OK Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Model selected: HUAWEI - Huawei C2830 Detected dead body ID: 0x122CE0E1 but resurrection time this error here is log Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.23, JTAG Manager Version: 1.32 Selected Resurrector: [Huawei C2830] Connecting to the dead body...OK Detected dead body ID: 0x122CE0E1 - IGNORED! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. |
Hi, DO NOT use max RTCK sampling with CDMA phones. In 99% cases it wont work. Set the RTCK Sampling rate to ~1MHz and retry. "ERROR: RAM memory selftest failed." Usually this error indicates HW problem, but in Your case it could be due to too high sampling rate. |
i can set rtck Sampling rate to ~1MHz but same problem Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.23, JTAG Manager Version: 1.32 Selected Resurrector: [Huawei C2830] Connecting to the dead body...OK Detected dead body ID: 0x122CE0E1 - IGNORED! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. |
Then check hardware. More precise - check sram chip. |
same problem Selected Resurrector: [Huawei C2830] Connecting to the dead body...OK Detected dead body ID: 0x122CE0E1 - IGNORED! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. b.r yuvi |
whats the problem in the set |
any body plz help me huawei c2830 bilinking Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.25, JTAG Manager Version: 1.33 Selected Resurrector: [Huawei C2830] Connecting to the dead body...OK Detected dead body ID: 0x122CE0E1 - CORRECT! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected a Not Initialized FLASH1 Chip ID: 0x0000/0x0000 (16MB) ERROR: Selected FLASH Chip was not initialized by the DCC Loader. whats the problem in the set |
