04-25-2011, 17:41 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: India [UNKNOWN]
Member: 1143809 Status: Offline Sonork: 100.1602432 Thanks Meter: 574 | huawei c2830 hang on tata logo not connect in riif box here is log Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.23, JTAG Manager Version: 1.32 Selected Resurrector: [Huawei C2830] Connecting to the dead body...ERROR Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Model selected: HUAWEI - Huawei C2830 ERROR: The RTCK Signal does not respond. |
04-27-2011, 08:04 | #5 (permalink) | |
Member: 1143809 Status: Offline Sonork: 100.1602432 Thanks Meter: 574 | Quote:
i check all connection but same problem The RTCK Signal does not respond. here is log Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.23, JTAG Manager Version: 1.32 Selected Resurrector: [Huawei C2830] Connecting to the dead body...ERROR Set I/O Voltage reads as 1.82V, TCK Frequency is RTCK Model selected: HUAWEI - Huawei C2830 ERROR: The RTCK Signal does not respond. | |
04-27-2011, 08:34 | #8 (permalink) |
Member: 1143809 Status: Offline Sonork: 100.1602432 Thanks Meter: 574 | i have 3 set hang on tata logo then off i try qsc1100 dll also but same error The RTCK Signal does not respond. here is log Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.23, JTAG Manager Version: 1.32 Selected Resurrector: [QSC1100 X14] Connecting to the dead body...ERROR Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Model selected: QUALCOMM (NOR) - QSC1100 X14 ERROR: The RTCK Signal does not respond. |
04-27-2011, 10:39 | #9 (permalink) |
Member: 1143809 Status: Offline Sonork: 100.1602432 Thanks Meter: 574 | huawei c2830 connected successfully huawei c2830 connected successfully here is log Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.23, JTAG Manager Version: 1.32 Selected Resurrector: [Huawei C2830] Connecting to the dead body...OK Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Model selected: HUAWEI - Huawei C2830 Detected dead body ID: 0x122CE0E1 but resurrection time this error here is log Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.23, JTAG Manager Version: 1.32 Selected Resurrector: [Huawei C2830] Connecting to the dead body...OK Detected dead body ID: 0x122CE0E1 - IGNORED! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. |
04-27-2011, 10:42 | #10 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Hi, DO NOT use max RTCK sampling with CDMA phones. In 99% cases it wont work. Set the RTCK Sampling rate to ~1MHz and retry. "ERROR: RAM memory selftest failed." Usually this error indicates HW problem, but in Your case it could be due to too high sampling rate. |
04-27-2011, 11:12 | #11 (permalink) | |
i can set rtck Sampling rate to ~1MHz but same problem Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.23, JTAG Manager Version: 1.32 Selected Resurrector: [Huawei C2830] Connecting to the dead body...OK Detected dead body ID: 0x122CE0E1 - IGNORED! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. | |
04-29-2011, 08:25 | #13 (permalink) |
No Life Poster Join Date: Jan 2006 Location: jharkhand jamshedpur INDIA Age: 38
Member: 226587 Status: Offline Sonork: 100.1603781 Thanks Meter: 352 | same problem Selected Resurrector: [Huawei C2830] Connecting to the dead body...OK Detected dead body ID: 0x122CE0E1 - IGNORED! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. b.r yuvi |
04-29-2011, 11:24 | #14 (permalink) | |
whats the problem in the set | |
07-07-2011, 18:10 | #15 (permalink) |
Freak Poster Join Date: Dec 2008 Location: kanpur
Member: 931438 Status: Offline Sonork: 1614828 Thanks Meter: 26 | any body plz help me huawei c2830 bilinking Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.25, JTAG Manager Version: 1.33 Selected Resurrector: [Huawei C2830] Connecting to the dead body...OK Detected dead body ID: 0x122CE0E1 - CORRECT! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected a Not Initialized FLASH1 Chip ID: 0x0000/0x0000 (16MB) ERROR: Selected FLASH Chip was not initialized by the DCC Loader. whats the problem in the set |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
Operator-Logo for 5110 | MiMiR the WiseMan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-25-1999 15:50 |
