11-08-2013, 13:41 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: india Age: 37
Member: 1146038 Status: Offline Thanks Meter: 196 | nokia lumia 520 boot repair done with riff .... :) |
The Following 3 Users Say Thank You to @@@___@@@ For This Useful Post: |
03-25-2014, 18:41 | #4 (permalink) |
No Life Poster Join Date: Nov 2003
Member: 44904 Status: Offline Thanks Meter: 45 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Nokia Lumia 520 V1.0.5149.18900] Connecting to the dead body...OK Detected dead body ID: 0x207D00E1 - CORRECT! Set I/O Voltage reads as 1.80V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...FAILED ERROR(0x42): Communication is not established. Terminating. with usb conected +power hold |
04-11-2014, 10:00 | #6 (permalink) |
Junior Member Join Date: Feb 2014 Location: Lucknow U.P. Age: 30
Member: 2120952 Status: Offline Thanks Meter: 1 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Nokia Lumia 520 V1.0.5149.18900] Connecting to the dead body...OK Detected dead body ID: 0x207D00E1 - CORRECT! Set I/O Voltage reads as 1.79V, TCK Frequency is 1 MHz Resurrection sequence started. Establish communication with the phone...FAILED ERROR(0x42): Communication is not established. Terminating. not working help pl!!!! |
05-21-2014, 07:13 | #7 (permalink) |
Member: 2120952 Status: Offline Thanks Meter: 1 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Nokia Lumia 520 V1.0.5149.18900] Connecting to the dead body...OK Detected dead body ID: 0x207D00E1 - CORRECT! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. . dont done help plzzz |
05-21-2014, 08:11 | #8 (permalink) |
05-21-2014, 08:51 | #10 (permalink) | |
Member: 2120952 Status: Offline Thanks Meter: 1 | lumia 520 Quote:
Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Nokia Lumia 520 V1.0.5149.18900] Connecting to the dead body...OK Detected dead body ID: 0x207D00E1 - CORRECT! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. . dont done help plzzz:conf used: | |
