03-06-2012, 14:34 | #271 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 06.03.2012 RIFF JTAG – Samsung SGH-T499 Dart (Samsung Tass) Unbrick – Boot Repair supported Repairing bricked Samsung T499 is easy with RIFF Box. Phone is auto powered on with USB Data Cable connected to the PC while battery is inside. In case you use the battery only please note you will have to press Power On key once. To resurrect Samsung T499:
Now phone is in bootable condition, that is, even if it does not start up normally, you can flash it using known flashing methods. To enter download mode:
The Following 25 Users Say Thank You to legija For This Useful Post: |
03-14-2012, 14:22 | #272 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 14.03.2012 RIFF JTAG – Samsung SGH-i727 Galaxy S II Skyrocket Unbrick – Dead Boot Repair, World First ! ! ! Repairing bricked Samsung I727 is easy with the RIFF Box. The device is based on the Qualcomm APQ8060 chipset. Note, one simple way to connect over JTAG – connect USB cable to PC and insert battery. In this case phone is automatically powered on. To resurrect Samsung I727:
Now phone is in bootable condition, that is, even if it does not start up normally, you can flash it using original Samsung downloader software to restore it to the working state. To enter download mode:
The Following 2 Users Say Thank You to legija For This Useful Post: |
03-14-2012, 14:25 | #273 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 14.03.2012 RIFF JTAG – T-Mobile Samsung SGH-T989 Galaxy S II Unbrick – Dead Boot Repair supported, World First ! ! ! Repairing bricked Samsung T989 is easy with the RIFF Box. The device is based on the Qualcomm APQ8060 chipset. Note, one simple way to connect over JTAG – connect USB cable to PC and insert battery. In this case phone is automatically powered on. To resurrect Samsung T989:
The Following 4 Users Say Thank You to legija For This Useful Post: |
03-14-2012, 14:30 | #274 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 14.03.2012 RIFF JTAG – HTC Sensation (HTC Pyramid) Unbrick, ModelID, CID, IMEI repair Supported Repairing bricked HTC Sensation is easy with the RIFF Box. Phone is auto powered on with USB Data Cable connected to the PC while battery is connected. Resurrector will reflash radio’s boot zone (except FSBL area) and will re-write PDA’s SPL version 1.18.0000. Additionally to SPL and Radio zones, the zone which contains Model ID is re-flashed too. Thus after resurrection phone will have Model ID = ‘PG5813000’. There is option to reflash BOOT and RECOVERY zones. To resurrect HTC Sensation:
Now phone is in bootable condition, that is, even if it does not start up normally you can flash it using known flashing methods. To enter download mode:
The Following 9 Users Say Thank You to legija For This Useful Post: |
03-14-2012, 17:09 | #275 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | HTC_Sensation_PG58130.dll ------------------------------------- - ID 0x304210E1 is added to allowed list |
The Following User Says Thank You to legija For This Useful Post: |
03-16-2012, 08:03 | #276 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Qualcomm FullImage Files Plugin v1.06 Samsung i9000-like FullImage Files Plugin v1.04 ------------------------------------- - Added 'Invert Selected' button for better convenience when user needs to select many partitions. - Single and Multiple partitions save (right-click mouse, "Save...") now uses 12-digit address representation in file name for better convenience of unexperienced users: JTAG Manager DCC Read/Write page address/Length fields are 12-digit wide, so it further decreases the possiblity of errouneous address input by an unexperienced person. Samsung_N7000_AP.dll ------------------------------------- - fixed bug in DCCLoader which wouldn't accept any data to be flashed |
The Following 3 Users Say Thank You to legija For This Useful Post: |
03-16-2012, 19:24 | #277 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | HTC_Sensation_PG58130.dll, HTC_EVO3D_PG86300 ------------------------------------- - by typing mistake in DLL sources, the HBOOT (SPL) was flashed into wrong address. Now is corrected. |
The Following 7 Users Say Thank You to legija For This Useful Post: |
03-19-2012, 16:51 | #278 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 19.03.2012 RIFF JTAG – HTC EVO View 4G Unbrick, Unlock, IMEI and CID update supported Repairing bricked HTC EvoView4G is easy using RIFF Box. Phone is auto powered on with USB Data Cable connected to the PC while battery is connected. Please note, battery presense is required. Some (or all) revisions of HTC EvoView4G boards have JTAG interface disabled (that is enable MARM JTAG Fuse is ****n in the MSM8255 chip). In this case the JTAG may be enabled only by firmware itself. This is done by the FSBL loader, so writing to FSBL area is artificially disabled in the DCC Loader code. DCC Loader will discard all flashing attempts into FSBL zone and will respond with success code as if flashing succeeded. In this way FSBL zone is protected while user still can flash full image files seamlessly. Resurrector will reflash radio’s boot zone (except FSBL area) and will re-write PDA’s SPL to 1.38.0000 version. Additionally to SPL and Radio zones, the zone which contains Model ID is re-flashed too. Thus after resurrection phone will have Model ID = ‘PG4120000’. There is option to reflash BOOT and RECOVERY zones. Please note, if your phone has the FSBL loader damaged and MCU has JTAG FUSE ****n then there is no way to resurrect your phone via JTAG interface. To resurrect HTC EvoView4G:
The Following 23 Users Say Thank You to legija For This Useful Post: |
03-21-2012, 12:38 | #279 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 21.03.2012 RIFF JTAG – HTC Sensation XL X315 / Bass (HTC Runnymede) Unbrick, Unlock, IMEI and CID update supported Repairing bricked HTC SensationXL (PI39200) is easy using RIFF Box. Phone is auto powered on with USB Data Cable connected to the PC while battery is connected. Some (or all) revisions of HTC SensationXL boards have JTAG interface disabled (that is enable MARM JTAG Fuse is ****n in the MSM8255 chip). In this case the JTAG may be enabled only by firmware itself. This is done by the FSBL loader, so writing to FSBL area is artificially disabled in the DCC Loader code. DCC Loader will discard all flashing attempts into FSBL zone and will respond with success code as if flashing succeeded. In this way FSBL zone is protected while user still can flash full image files seamlessly. Resurrector will reflash radio’s boot zone (except FSBL area) and will re-write PDA’s SPL to 1.25.0004 version. Additionally to SPL and Radio zones, the zone which contains Model ID is re-flashed too. Thus after resurrection phone will have Model ID = ‘PG3920000’. There is option to reflash BOOT and RECOVERY zones. Please note, if your phone has the FSBL loader damaged and MCU has JTAG FUSE ****n then there is no way to resurrect your phone via JTAG interface. To resurrect HTC SensationXL:
03-21-2012, 13:09 | #280 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | RIFF JTAG – Samsung GT-P6810 Galaxy Tab 7.7 WiFi 16GB Unbrick – Dead Boot repair supported, World First ! ! ! Repairing bricked Samsung GT-P6810 Galaxy Tab 7.7 WiFi 16GB is easy with RIFF Box. Samsung P6810 is based on the Exynos Processor (Cortex-A9 Dual-Core). JTAG pads are very small; professional experience in soldering is required to connect wires to the JTAG interface. Note, one simple way to connect over JTAG – connect USB cable to PC and insert battery. In this case phone is automatically powered on. To resurrect Samsung P6810:
The Following 5 Users Say Thank You to legija For This Useful Post: |
03-27-2012, 17:58 | #282 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 27.03.2012 RIFF JTAG – Samsung SCH-I500 Galaxy S Mesmerize/Fascinate Unbrick Supported Repairing bricked Samsung SCH-I500 Galaxy S Mesmerize/Fascinate is easy with RIFF Box. I500 is based on the S5PCxxx Processor (ARM core is Cortex-A8). Please note the adaptive clocking mode (RTCK) is not available on this processor, so make sure to select a fixed TCK frequency. To establish the JTAG connection attach battery cable and press Power On key. In case after resurrection the download mode is not initiated (LCD remains blank) do repeat resurrection with ‘Clone Gremlin zone’ option checked. To resurrect Samsung I500:
The Following 16 Users Say Thank You to legija For This Useful Post: |
Does any one know how to program the ESN number with nokia 6120? | Bert | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-02-1999 10:45 |
SMS via system connector | pasisoft | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-21-1999 11:05 |
no one can unlock 6110 05.40 25-5-99 | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 09-22-1999 08:03 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
