02-09-2013, 13:26 | #1 (permalink) |
No Life Poster Join Date: May 2008
Member: 774169 Status: Offline Thanks Meter: 123 | s5570 -- still dead after i resurrect i have dead s5570 , which is dead while i was updating it . after that i erased it using riff . resurrected it . 100% resurrection successfull. still handset not switching on , neither its going to boot mode . Experts pls help me in reviving this phone . regards suraj |
02-09-2013, 13:39 | #3 (permalink) |
No Life Poster Join Date: Jul 2011 Location: ۞_ KERALA__۞_INDIA
Member: 1619462 Status: Offline Sonork: 100.1606509 Thanks Meter: 1,517 | Why u erased? to repair boot. just Resurrect. Just use Help button and read all before doing. Ok . try to poweron, is its shows red or pink display? Else.. Repair boot in Z3x, and flash fone with Downloader. Repair IMEI after that with Z3x. Done! |
The Following User Says Thank You to .::EXTREME::. For This Useful Post: |
02-09-2013, 13:46 | #4 (permalink) |
Member: 774169 Status: Offline Thanks Meter: 123 | thanks sir , But after i erased since after resurrecting it many time when still it was not powering on / going in boot mode , then i decided to flash . resurrection 100% complete , still no power on no boot mode no pink screen . as far z3x boot repair , i will do and report it here . thanks for instant reply to @EXTREME regards suraj |
02-09-2013, 13:48 | #5 (permalink) |
No Life Poster Join Date: Aug 2001 Location: Roma Age: 49
Member: 5926 Status: Offline Thanks Meter: 275 | use full dump for riff. search for S5570_full_first.rar or Here if everything hw is ok, after write full dump phone must power on. then repair imei with z3x. |
02-09-2013, 14:00 | #7 (permalink) |
Member: 1619462 Status: Offline Sonork: 100.1606509 Thanks Meter: 1,517 | Oh! can't repair MSM7227 Platform srry! Just do this.. write full dump [ check above post for Dump] "to restore backup, do this : - Switch to "DCC Read/Write" TAB - Select "Access ROM1 Address Space" - Check "Auto Fullflash size" - In "main" field open desired backup file - Check "Image Files use Used" - Check "Use Address as Offset for Flash Files" - Click "Write Flash" " Then - repair boot(resurrection) - full flash ( boot+ other files) and phone become to normal state. |
The Following 2 Users Say Thank You to .::EXTREME::. For This Useful Post: |
05-08-2013, 15:47 | #8 (permalink) |
Junior Member Join Date: May 2013
Member: 1930058 Status: Offline Thanks Meter: 0 | Salve ragazzi potete auitarmi a riparare il mio samsung s5570 ho visto sul furom un file (s5570 full frist ) lo scaricato ma non so come metterlo sul telefono grazie in anticipo |
05-08-2013, 16:15 | #9 (permalink) |
09-12-2013, 11:57 | #10 (permalink) | |
Registered User Join Date: Mar 2006 Location: Pilipinas
Member: 249276 Status: Offline Thanks Meter: 209 | tested Quote:
Br, Mister G | |
