Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > RIFF Box Team > RIFFBOX
Old 01-13-2011, 19:20   #1 (permalink)
ten_sev's Avatar
Member: 381039
Sonork: 100.1603121
Thanks Meter: 12
Galaxy tab
I have a samsung p1000 I repair the boot with the riff and now the box turns on and remains on samsung GALAXY TAB. I flashed it but until then make m ^ me something and I wanted to know if there has a solution. please do help NEED FOR
Old 01-14-2011, 12:01   #2 (permalink)
Member: 596972
Sonork: 100.1591686
Thanks Meter: 55
Flash the tab with odin. After flashing probably need to install the dbdata manual
Old 01-15-2011, 19:20   #3 (permalink)
ten_sev's Avatar
Member: 381039
Sonork: 100.1603121
Thanks Meter: 12
Galaxy tab p1000
I need the firmware samsung GALAXY TAB P1000 which is the file or TAR file PDA, MODEM, CSC if you helped me
Old 01-15-2011, 19:53   #4 (permalink)
Member: 47716
Thanks Meter: 14
[Guide] Flashing Samsung Galaxy Tab - The Galaxy Tab Forum
Old 01-19-2011, 14:09   #5 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 497
P1000 Help needed .
I have recieve this phone in bricked condition .. customer said that after update by Odin , it went completely dead .
so i did resurrection . but still bricked , then i did with Tiked Linux + Goblin .. but still same bricked .
Open serial port...OK
Connecting to the RIFF Box...OK
Firmware Version: 1.16, JTAG Manager Version: 1.22
Selected Resurrector: [Samsung Galaxy Tab]
Connecting to the dead body...OK
Detected dead body ID: 0x1BA00477 - CORRECT!
Set I/O Voltage reads as 2.81V, TCK Frequency is 8 MHz
Resurrection sequence started.
Establish communication with the phone...OK
Initializing internal hardware configuration...OK
Uploading resurrector data into memory...OK
Starting communication with resurrector...OK
Detected an Initialized FLASH1 Chip ID: 0x00EC/0x0050 (512MB)
Flashing the dead body...OK
Resurrection complete!
I have p1000 not the M version .
will i required full dump ?
help is urgently needed .
Old 01-19-2011, 15:45   #6 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 497
Any help ..........................
Old 01-19-2011, 16:08   #7 (permalink)
Member: 596972
Sonork: 100.1591686
Thanks Meter: 55
hmmm i had bricked P1000 in my office. Ressurection was good, and flashing after with Odin 1.7 was no problem.
Can you start the download mode?
Old 01-19-2011, 18:19   #8 (permalink)
smartecs's Avatar
Member: 42370
Thanks Meter: 32
after Ressurection..can you put your p1000 in download mode by hold volumn down+power on?
Old 01-19-2011, 18:54   #9 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 497
I am sorry guy .. Battery was dead Flat ..
After charging for 4 hours via desktop charger .. Phone is now going to Download mode ..
so i decided to flash with European firmware with its Pit + PDA + CSC ... Flashing went successful but phone Powered ON in Recovery mode ..
Do i decided again to flash via Arabic firmware with its PITS .. don't know what the fcukk thing happen .. Now its completely dead again ...
Well i'll Do resurrect again tomorrow but whats the correct proceedure to FLash this Dam phone ?
Old 01-19-2011, 22:45   #10 (permalink)
Member: 596972
Sonork: 100.1591686
Thanks Meter: 55
Its very easy
You can flash european version after flashing the phone goes in recovery mode to install the dbdata. If this was not possible flash the dbdata manually in PDA-Section. After flashing dbdata hold power an volume up to restart the tab. If the tab restarts let of the power button and hold the volume-up to go into manual installation mode. Now the Tab should install the dbdata manually and make an restart. Then it should boot normaly.
If you need dbdata for this tab i can send you a download-link
Note if you flash the european version flash only the OXAJK5 or XXJK5. This versions are the latest officially Samsung Versions. And as i know they have no signed bootloader. All newer versions had new signed bootloader so after flashing you can't downgrade anymore (i don't know if you can downgrade after ressurecting with RIFF again)
Old 01-19-2011, 23:23   #11 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 497
sure send me db data ... what the hell is this . i dont know about it
also please provide me the link of the versions you are saying
Old 01-20-2011, 02:33   #12 (permalink)
ten_sev's Avatar
Member: 381039
Sonork: 100.1603121
Thanks Meter: 12
Gt p1000 galaxy tab
I have problems with the samsung p1000 I repair the boot with RIFF BOX it and I flacher but still does not work. I wanted to know if there is another solution for the repair to wane and with the soft boot
Old 01-20-2011, 11:18   #13 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 497
hello ?
you were sending that dbdata ?
Old 01-20-2011, 13:38   #14 (permalink)
Member: 596972
Sonork: 100.1591686
Thanks Meter: 55
Link to the dbdata: http://rapidshare.com/files/443561834/dbdata.rar
The link to the firmware will follow asap. No the file is in Upload
And use odin3 v1.7 to flash the tab
dbdata is the same as csc. When you don't install the dbdata you can't see correct informations of firmware in the tab. The tab will hang on Galaxy Tab when start the tab.
This error come when you flash 1-File-Firmware.
The Following User Says Thank You to jomafi For This Useful Post:
Old 01-20-2011, 13:56   #15 (permalink)
Member: 596972
Sonork: 100.1591686
Thanks Meter: 55
Here the Firmwarefile: http://rapidshare.com/files/443564612/P1000OXAJK5.tar
nokia 5110 dead alpha Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 02-28-2001 11:59
8810 & 8210 Phone NOT respond! (Load Boot data) AboAli Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 02-25-2001 14:47
F_loaders.bin and Boot.bin .. . micklong Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 01-29-2001 14:49
Phone not respond! (Load boot data) Need a help ! SashaM Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 01-23-2001 02:10
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) tcamilo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 12-19-1999 22:30
Page generated in 0.28611 seconds with 10 queries
