Samsung I727 Memory Hi Forum, I have a Galaxy S2 LTE I747-R from Rogers Canada... its completely dead and when i try to revive it there is some error with the memory.... I cannot find a dump for it... so i was wondering i do have a working i727... what is the procedure to read from a working phone and then write on the bad one? Any help is grately appreciated.... |
Hello ...posting a log file of the resurrection would help us understand better. |
jtag chain response Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung I727 V1.0.4455.8370] Connecting to the target...OK Set I/O Voltage reads as 1.80V, TCK Frequency is RTCK Following devices are found on the JTAG chain: Device on TAP #0: ID = 0x106A10E1, IR Length = 0x0B bits Total IR length: 0x000B bits Analizing IDCODE(s) of the JTAG scan chain: 1. 0x106A10E1: Qualcomm APQ8060, H/W Rev. #1 Ressurection mode Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung I727 V1.0.4455.8370] Connecting to the dead body...OK Detected dead body ID: 0x106A10E1 - CORRECT! Set I/O Voltage reads as 1.80V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: No response from the RIFF Box. DCC Read Write Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung I727 V1.0.4455.8370] Connecting to the dead body...OK Detected dead body ID: 0x106A10E1 - CORRECT! Set I/O Voltage reads as 1.80V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x24000000000000000000000400000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: No response from the RIFF Box. Any help is appreciated |
Fixed!!! 1 Attachment(s) Hi Guys, I was able to figure it out... it was a connections issue.... what i did was plugged the usb cable and my jtag connection... no need to press power button or connect the battery source... worked for mee see the attached.... |
