Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > RIFF Box Team > RIFFBOX
Old 03-14-2013, 01:24   #1 (permalink)
Member: 1744748
Thanks Meter: 752
Samsung I727 Memory
Hi Forum,
I have a Galaxy S2 LTE I747-R from Rogers Canada... its completely dead and when i try to revive it there is some error with the memory....
I cannot find a dump for it... so i was wondering i do have a working i727... what is the procedure to read from a working phone and then write on the bad one?
Any help is grately appreciated....
Old 03-14-2013, 01:43   #2 (permalink)
spagman's Avatar
Member: 1783314
Sonork: 100.1620532
Thanks Meter: 127
Hello ...posting a log file of the resurrection would help us understand better.
Old 03-14-2013, 03:47   #3 (permalink)
Member: 1744748
Thanks Meter: 752
jtag chain response
Open serial port...OK
Connecting to the RIFF Box...OK
Firmware Version: 1.34, JTAG Manager Version: 1.48
Selected Resurrector: [Samsung I727 V1.0.4455.8370]
Connecting to the target...OK
Set I/O Voltage reads as 1.80V, TCK Frequency is RTCK
Following devices are found on the JTAG chain:
Device on TAP #0: ID = 0x106A10E1, IR Length = 0x0B bits
Total IR length: 0x000B bits
Analizing IDCODE(s) of the JTAG scan chain:
1. 0x106A10E1: Qualcomm APQ8060, H/W Rev. #1
Ressurection mode
Connecting to the dead body...OK
Detected dead body ID: 0x106A10E1 - CORRECT!
Adaptive Clocking RTCK Sampling is: [Sample at MAX]
Resurrection sequence started.
Establish communication with the phone...OK
Initializing internal hardware configuration...OK
Uploading resurrector data into memory...FAILED
ERROR: No response from the RIFF Box.
DCC Read Write
Settings Code: 0x24000000000000000000000400000000
Any help is appreciated
Old 03-14-2013, 04:20   #4 (permalink)
Member: 1744748
Thanks Meter: 752
Fixed!!!
Hi Guys,
I was able to figure it out... it was a connections issue.... what i did was plugged the usb cable and my jtag connection... no need to press power button or connect the battery source...
worked for mee see the attached....
Page generated in 0.13854 seconds with 9 queries
