01-20-2012, 23:30 | #1 (permalink) |
Junior Member Join Date: Apr 2009
Member: 1021526 Status: Offline Thanks Meter: 3 | Tab P1010 no bootable condition after RIFF Fisrt, thanks for that resurrector. I succeeded in applying resurestion to my P1010 with iRAM but still no bootable condition is available. Each time I will connect the Tab to the PC I will have the famous "OMAP3630" thing. "Vol Down+Power" does nothing. I tried with repairing Gremlin Zone. No success ! I tried with different RTCK speed : at Max (12MHz ???) at 4MHz and 1MHz. No success ! On each try resurrection is complete with no errors ! Anyone have a direction please ? Thanks |
01-21-2012, 11:59 | #3 (permalink) | |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Quote:
Please provide some information about device history, what is the reason You needed to repair it at first place? And of course, include logs from Your resurrection attempts. | |
The Following User Says Thank You to legija For This Useful Post: |
01-23-2012, 18:38 | #4 (permalink) |
Member: 1021526 Status: Offline Thanks Meter: 3 | According to what ulad said, I made a new try. Same results. Here's the log. Legija, the history is quite simple. I flahsed the P1010 with P1000 firmware, so bricked it !!! Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.30, JTAG Manager Version: 1.38 Selected Resurrector: [Samsung P1010 (via IRAM)] Connecting to the dead body...OK Detected dead body ID: 0x0B6D602F - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 8 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB) Flashing the dead body...OK Resurrection complete! Thanks your help guys. |
01-23-2012, 18:52 | #5 (permalink) |
Member: 1021526 Status: Offline Thanks Meter: 3 | I forgot to say that I also tried to resurrect it with P1000 resurrector, and interface pinout !!! (Sorry but the devices look really the same and I could not imagined those differences). o_O DOn't tell me that I ruined it ! |
01-24-2012, 22:48 | #6 (permalink) |
Junior Member Join Date: Apr 2011
Member: 1555702 Status: Offline Thanks Meter: 1 | Dear Mr. Legija, I have a P1010 with flashed P1000 firmware, too. Resurrection wit P1010 IRAM is finished without errors. But I can't get into download mode. When I connect USB cable, the empty battery is shown on the display but the empty status doesn't change. When I disconnect the USB cable and reconnect it, the devices shows the battery for a few seconds (my notebook shows an unknown usb device), then the tab seems to power off and then it shows the battery again, and so on ... It's a kind of loop. The device isn't powered on by hitting the power button. No button combination brings me to downlode mode. Can you please provide any help or a fix for this? Regards, onkeltom |
01-24-2012, 22:54 | #7 (permalink) |
Member: 1555702 Status: Offline Thanks Meter: 1 | This is the log: Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.30, JTAG Manager Version: 1.38 Selected Resurrector: [Samsung P1010 (via IRAM)] Connecting to the dead body...OK Detected dead body ID: 0x0B6D602F - CORRECT! Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB) Flashing the dead body...OK Resurrection complete! |
01-25-2012, 03:43 | #8 (permalink) | |
Freak Poster Join Date: Jan 2009 Location: Germany/NRW
Member: 936229 Status: Offline Sonork: 1606911 Thanks Meter: 115 | Quote:
I had often same problem after resurection with P1000,P1010,because Battery is totaly empty,but that is normaly and Boot ist too ok! Connect via USB Cable or Power Cable and disconect LCD connector from Board and few hours can be charged,then you can flash with Odin from Download Mode and it will be ok. | |
The Following 2 Users Say Thank You to Pulka For This Useful Post: |
5110/6110 after unlocking see only network to which it was locked and ... | 2M | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 07-25-2000 00:51 |
6150 no outgoing calls | edis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-20-2000 20:19 |
5110 5.24 locked all 4 locks after unlocking... | MCG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-07-2000 22:24 |
no one can unlock 6110 05.40 25-5-99 | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 09-22-1999 08:03 |
"Menu 11"? after Net monitor | Pyron | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 08-09-1999 10:07 |
