06-28-2012, 09:55 | #76 (permalink) |
Junior Member Join Date: Jun 2012
Member: 1777892 Status: Offline Thanks Meter: 0 | I have a bricked Nexus that wont boot, only response is "OMAP4440" driver popping up in Windows. I installed the driver from the package from post #1 and this is what I get from cmd window: Code: » OMAPFlash v4.15 (Aug 12 2011) » -v » Entering parameter file:Targets\Projects\tuna\omap4460_tuna_hs_pro.txt at line: 1 » -omap 4 » -t 36000 » -p OMAP4460_TUNA_8G_HS_PRO » -2 » -rxtx_trace » chip_download EMMC Targets\Projects\tuna\MLO_4460_HS_PRO » chip_download EMMC Targets\Projects\tuna\sbl.img » command cold_sw_reset » Leaving parameter file:Targets\Projects\tuna\omap4460_tuna_hs_pro.txt » @Targets\Projects\tuna\omap4460_tuna_hs_pro.txt » Looking for device (omap usb) » Please turn on device » Waiting for device (omap usb) » Found device (omap usb) » Requesting ASIC id 00130-000-TX 4 raw bytes: 03 00 03 F0 '????' » AsicId items 05 » AsicId id 01 05 01 44 40 07 01 » AsicId secure_mode 13 02 01 00 » AsicId public_id 12 15 01 F7 4E 95 42 0E 03 0F 91 21 E4 42 51 C9 0B CC 21 7D EC 40 FE » AsicId root_key_hash 14 21 01 67 98 9B 35 54 CC 86 B4 67 32 47 05 36 74 E2 25 F0 9D A3 5C F4 59 B9 C9 3A 13 E0 B9 58 1E 5A BC » AsicId checksum 15 09 01 22 9E 85 BA DC 58 74 BC 00130-001-TX 4 raw bytes: 02 00 03 F0 '????' » Searching 2nd for: OMAP4460_TUNA_8G_HS_PRO 444007 01 HS » Loading second file Targets/2nd-Downloaders/dnld_startup_omap4_hs_8g_es2.s2.signed.2nd.hs_pro » Entering parameter file:omapflash2nd.txt at line: 46 » -pheriphalboot_reopen » Reading board configuration file Targets\Configurations\configuration_omap4460_tuna_8g.txt » Reading definition file .\targets\definitions\definitions_omap4.txt » -board_config Targets\Configurations\configuration_omap4460_tuna_8g.txt » Leaving parameter file:omapflash2nd.txt » Sending size of second file (0x000071B0 bytes) 00130-002-TX 4 raw bytes: B0 71 00 00 '?q??' » Transferring second file to target (0x71B0 bytes) 00130-003-TX 29104 raw bytes: B0 1C 00 00 00 4D 00 00 00 00 00 00 00 00 00 00 '?????M??????????' ... » Closing boot connection » Found device (omap usb) » Waiting for 2nd 00463-004-TX ACK 00554-005-RX:OKAY: 2nd started » Found 2nd » Looking for a driver for 'EMMC' » chip_driver EMMC Targets\Flash-Drivers\emmc_drv.bin sid 0 width 4 delay 9 rpapi_base 0x00030400 » Downloading driver 00385-006-TX:driver EMMC sid 0 width 4 delay 9 rpapi_base 0x00030400 00463-007-TX ACK 00554-008-RX:OKAY: expecting download » Downloading 'Targets\Flash-Drivers\emmc_drv.bin' 00385-009-TX:download:0000b838 00527-010-RX:data00018000 » Sending data (47160 bytes) :::::::::::::....... [32768] 00148-011-TX 32768 bin bytes 00527-012-RX:data00013838 » Sending data (47160 bytes) :::::::::::::::::::: [47160] 00148-013-TX 14392 bin bytes » Sending data (47160 bytes) :::::::::::::::::::: [47160] 00463-014-TX ACK 00483-015-RX:INFO: Interface 'OMAPFLASH DRIVER v6' Interface 'OMAPFLASH DRIVER v6' 00463-016-TX ACK 00483-017-RX:INFO: Driver 'eMMC JESD84-A43' Driver 'eMMC JESD84-A43' 00463-018-TX ACK 00483-019-RX:INFO: Driver configuration: sid = 0x00000000 Driver configuration: sid = 0x00000000 00463-020-TX ACK 00483-021-RX:INFO: Driver configuration: width = 0x00000004 Driver configuration: width = 0x00000004 00463-022-TX ACK 00483-023-RX:INFO: Driver configuration: delay = 0x00000009 Driver configuration: delay = 0x00000009 00463-024-TX ACK 00483-025-RX:INFO: Driver configuration: rpapi_base = 0x00030400 Driver configuration: rpapi_base = 0x00030400 00463-026-TX ACK 00483-027-RX:INFO: MMC sid = 0x00 MMC sid = 0x00 00463-028-TX ACK 00483-029-RX:INFO: MMC mmc_volt = 0x01 MMC mmc_volt = 0x01 00463-030-TX ACK 00483-031-RX:INFO: MMC data_width = 0x04 MMC data_width = 0x04 00463-032-TX ACK 00483-033-RX:INFO: MMC card_rca = 0x00 MMC card_rca = 0x00 00463-034-TX ACK 00483-035-RX:INFO: MMC card_type = 0x00 MMC card_type = 0x00 00463-036-TX ACK 00483-037-RX:INFO: MMC data_width_support = 0x00 MMC data_width_support = 0x00 00463-038-TX ACK 00483-039-RX:INFO: MMC transfer_clk_max = 0x00 MMC transfer_clk_max = 0x00 00463-040-TX ACK 00483-041-RX:INFO: MMC card_size = 0x00 MMC card_size = 0x00 00463-042-TX ACK 00483-043-RX:INFO: MMC mmc_config return 0x00FF8080 MMC mmc_config return 0x00FF8080 00463-044-TX ACK 00483-045-RX:INFO: EMMC eMMC DRIVER DEINIT COMPLETE EMMC eMMC DRIVER DEINIT COMPLETE 00463-046-TX ACK 00494-047-RX:FAIL: Driver init error 0x00FF8080 - MMC CONFIG FAILURE » Download failed (final data response error): Remote: : Driver init error 0x00FF8080 - MMC CONFIG FAILURE » Elapsed time: 0:05.445 (8730 bytes/s) » Operation FAILED (Remote: : Driver init error 0x00FF8080 - MMC CONFIG FAILURE) » Elapsed time: 0:20.860 I also try this on W7 x64 and WXP x86 but no joy on any of these systems. Eve tried different USB cables, put the phone to fridge for few minutes (cuz I read about some heat sensor inside - also this trick helped me to fix my HTC Desire before ) If I compare my log with log of xanders2615 (post #73) my differences starting here: Code: 00483-033-RX:INFO: MMC card_rca = 0x00 MMC card_rca = 0x00 00463-034-TX ACK 00483-035-RX:INFO: MMC card_type = 0x00 MMC card_type = 0x00 00463-036-TX ACK 00483-037-RX:INFO: MMC data_width_support = 0x00 MMC data_width_support = 0x00 00463-038-TX ACK 00483-039-RX:INFO: MMC transfer_clk_max = 0x00 MMC transfer_clk_max = 0x00 00463-040-TX ACK 00483-041-RX:INFO: MMC card_size = 0x00 MMC card_size = 0x00 Code: 00483-033-RX:INFO: MMC card_rca = 0x04 MMC card_rca = 0x04 00463-034-TX ACK 00483-035-RX:INFO: MMC card_type = 0x03 MMC card_type = 0x03 00463-036-TX ACK 00483-037-RX:INFO: MMC data_width_support = 0x08 MMC data_width_support = 0x08 00463-038-TX ACK 00483-039-RX:INFO: MMC transfer_clk_max = 0xBB80 MMC transfer_clk_max = 0xBB80 00463-040-TX ACK 00483-041-RX:INFO: MMC card_size = 0x1D5A000 MMC card_size = 0x1D5A000 Thanks for the reply... |
07-03-2012, 23:46 | #79 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Quote:
Hi Yes,eMMC is damaged and need replace by new one | |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
07-05-2012, 20:40 | #80 (permalink) |
Member: 1775106 Status: Offline Thanks Meter: 1 | so p1ceus GN eMMC is damaged, mine is showing different information, Do you have any clue on what could be the issue with my GN? I try the OMAP Flash and it get stuck downloading data. Did you know if the JTAG could resurrect my phone? Thank you. |
07-12-2012, 05:06 | #81 (permalink) |
Junior Member Join Date: Jul 2012
Member: 1783418 Status: Offline Thanks Meter: 0 | Hi all, I have a bricked 9250 Galaxy Nexus and tried using the awesome script that legjia so generously posted, but the tool appears to be hanging at one of the "Downloading" stages. Any idea if there might be a setting I need to tweak, or do I just have dead memory/motherboard? If legjia, itsallgood or anyone else can help, I would be very grateful! Output pasted below: Code: » OMAPFlash v4.15 (Aug 12 2011) » -v » Entering parameter file:Targets\Projects\tuna\omap4460_tuna_hs_pro.txt at line : 1 » -omap 4 » -t 36000 » -p OMAP4460_TUNA_8G_HS_PRO » -2 » chip_download EMMC Targets\Projects\tuna\MLO_4460_HS_PRO » chip_download EMMC Targets\Projects\tuna\sbl.img » command cold_sw_reset » Leaving parameter file:Targets\Projects\tuna\omap4460_tuna_hs_pro.txt » @Targets\Projects\tuna\omap4460_tuna_hs_pro.txt » Looking for device (omap usb) » Please turn on device » Waiting for device (omap usb) » Found device (omap usb) » Requesting ASIC id » AsicId items 05 » AsicId id 01 05 01 44 40 07 01 » AsicId secure_mode 13 02 01 00 » AsicId public_id 12 15 01 5A A8 E8 A8 53 BD EE 8C D6 05 C2 49 0C 2C 43 E0 CB D6 17 C7 » AsicId root_key_hash 14 21 01 67 98 9B 35 54 CC 86 B4 67 32 47 05 36 74 E2 25 F0 9D A3 5C F4 59 B9 C9 3A 13 E0 B9 58 1E 5A BC » AsicId checksum 15 09 01 22 9E 85 BA DC 58 74 BC » Searching 2nd for: OMAP4460_TUNA_8G_HS_PRO 444007 01 HS » Loading second file Targets/2nd-Downloaders/dnld_startup_omap4_hs_8g_es2.s2.si gned.2nd.hs_pro » Entering parameter file:omapflash2nd.txt at line: 46 » -pheriphalboot_reopen » Reading board configuration file Targets\Configurations\configuration_omap4460 _tuna_8g.txt » Reading definition file .\targets\definitions\definitions_omap4.txt » -board_config Targets\Configurations\configuration_omap4460_tuna_8g.txt » Leaving parameter file:omapflash2nd.txt » Sending size of second file (0x000071B0 bytes) » Transferring second file to target (0x71B0 bytes) » Closing boot connection » Found device (omap usb) » Waiting for 2nd » Found 2nd » Looking for a driver for 'EMMC' » chip_driver EMMC Targets\Flash-Drivers\emmc_drv.bin sid 0 width 4 delay 9 rpap i_base 0x00030400 » Downloading driver » Downloading 'Targets\Flash-Drivers\emmc_drv.bin' » Sending data (47160 bytes) :::::::::::::::::::: [47160] Interface 'OMAPFLASH DRIVER v6' Driver 'eMMC JESD84-A43' Driver configuration: sid = 0x00000000 Driver configuration: width = 0x00000004 Driver configuration: delay = 0x00000009 Driver configuration: rpapi_base = 0x00030400 MMC sid = 0x00 MMC mmc_volt = 0x01 MMC data_width = 0x04 MMC card_rca = 0x04 MMC card_type = 0x03 MMC data_width_support = 0x08 MMC transfer_clk_max = 0xBB80 MMC card_size = 0x1D5A000 eMMC CID MID = 0x15 // Manufacturer ID eMMC CID CBX = 0x01 // Card/BGA eMMC CID OID = 0x00 // OEM/Application ID eMMC CID PNM = 0x34280000BEFB // Product name eMMC CID PRV = 0x25 // Product revision eMMC CID PSN = 0x0000BEFB // Product serial numbe r eMMC CID MDT = 0xBE // Manufacturing date eMMC CID CRC = 0x7D // CRC7 checksum eMMC CSD CSD_STRUCTURE = 0x03 // CSD structure eMMC CSD SPEC_VERS = 0x04 // System specification version eMMC CSD TAAC = 0x27 // Data read access-tim e 1 eMMC CSD NSAC = 0x01 // Data read access-tim e 2 in CLK cycles (NSAC*100) eMMC CSD TRAN_SPEED = 0x32 // Max. bus clock frequ ency eMMC CSD CCC = 0x00F5 // Card command classes eMMC CSD READ_BL_LEN = 0x09 // Max. read data block length eMMC CSD READ_BL_PARTIAL = 0x00 // Partial blocks for r ead allowed eMMC CSD WRITE_BLK_MISALIGN = 0x00 // Write block misalign ment eMMC CSD READ_BLK_MISALIGN = 0x00 // Read block misalignm ent eMMC CSD DSR_IMP = 0x00 // DSR implemented eMMC CSD C_SIZE = 0x00FF // Device size eMMC CSD VDD_R_CURR_MIN = 0x06 // Max. read current @ VDD min eMMC CSD VDD_R_CURR_MAX = 0x06 // Max. read current @ VDD max eMMC CSD VDD_W_CURR_MIN = 0x06 // Max. write current @ VDD min eMMC CSD VDD_W_CURR_MAX = 0x06 // Max. write current @ VDD max eMMC CSD C_SIZE_MULT = 0x01 // Device size multipli er eMMC CSD ERASE_GRP_SIZE = 0x1F // Erase group size eMMC CSD ERASE_GRP_MULT = 0x1F // Erase group size mul tiplier eMMC CSD WP_GRP_SIZE = 0x0F // Write protect group size eMMC CSD WP_GRP_ENABLE = 0x01 // Write protect group enable eMMC CSD DEFAULT_ECC = 0x00 // Manufacturer default ECC eMMC CSD R2W_FACTOR = 0x02 // Write speed factor eMMC CSD WRITE_BL_LEN = 0x09 // Max. write data bloc k length eMMC CSD WRITE_BL_PARTIAL = 0x00 // Partial blocks for w rite allowed eMMC CSD CONTENT_PROT_APP = 0x00 // Content protection a pplication eMMC CSD FILE_FORMAT_GRP = 0x00 // File format group eMMC CSD COPY = 0x01 // Copy flag (OTP) eMMC CSD PERM_WRITE_PROTECT = 0x00 // Permanent write prot ection eMMC CSD TMP_WRITE_PROTECT = 0x00 // Temporary write prot ection eMMC CSD FILE_FORMAT = 0x00 // File format eMMC CSD ECC = 0x00 // ECC code eMMC CSD CRC = 0x33 // CRC eMMC EXT_CSD S_CMD_SET = 0x00 // Supported Command Se ts eMMC EXT_CSD BOOT_INFO = 0x15 // Boot information eMMC EXT_CSD BOOT_SIZE_MULTI = 0x0A // Boot partition size eMMC EXT_CSD ACC_SIZE = 0x07 // Access size eMMC EXT_CSD HC_ERASE_GRP_SIZE = 0x00 // High-capacity erase unit size eMMC EXT_CSD ERASE_TIMEOUT_MULT = 0x04 // High-capacity erase timeout eMMC EXT_CSD REL_WR_SEC_C = 0x07 // Reliable write secto r count eMMC EXT_CSD HC_WP_GRP_SIZE = 0x01 // High-capacity write protect group size eMMC EXT_CSD S_C_VCC = 0x01 // Sleep current (VCC) eMMC EXT_CSD S_C_VCCQ = 0x01 // Sleep current (VCCQ) eMMC EXT_CSD S_A_TIMEOUT = 0x07 // Sleep/awake timeout eMMC EXT_CSD SEC_COUNT = 0x01D5A000 // Sector Count eMMC EXT_CSD MIN_PERF_W_8_52 = 0xA0 // Minimum Write Perfor mance for 8bit at 52MHz eMMC EXT_CSD MIN_PERF_R_8_52 = 0x00 // Minimum Read Perform ance for 8bit at 52MHz eMMC EXT_CSD MIN_PERF_W_8_26_4_52 = 0x00 // Minimum Write Perfor mance for 8bit at 26MHz, for 4bit at 52MHz eMMC EXT_CSD MIN_PERF_R_8_26_4_52 = 0x00 // Minimum Read Perform ance for 8bit at 26MHz, for 4bit at 52MHz eMMC EXT_CSD MIN_PERF_W_4_26 = 0x00 // Minimum Write Perfor mance for 4bit at 26MHz eMMC EXT_CSD MIN_PERF_R_4_26 = 0x00 // Minimum Read Perform ance for 4bit at 26MHz eMMC EXT_CSD PWR_CL_26_360 = 0x00 // Power class for 26MH z at 3.6V eMMC EXT_CSD PWR_CL_52_360 = 0x00 // Power class for 52MH z at 3.6V eMMC EXT_CSD PWR_CL_26_195 = 0x00 // Power class for 26MH z at 1.95V eMMC EXT_CSD PWR_CL_52_195 = 0x00 // Power class for 52MH z at 1.95V eMMC EXT_CSD CARD_TYPE = 0x01 // Card type eMMC EXT_CSD CSD_STRUCTURE = 0x00 // CSD structure versio n eMMC EXT_CSD EXT_CSD_REV = 0x00 // Extended CSD revisio n eMMC EXT_CSD CMD_SET = 0x02 // Command set eMMC EXT_CSD CMD_SET_REV = 0x05 // Command set revision eMMC EXT_CSD POWER_CLASS = 0x00 // Power class eMMC EXT_CSD HS_TIMING = 0x00 // High-speed interface timing eMMC EXT_CSD BUS_WIDTH = 0x00 // Bus width mode eMMC EXT_CSD ERASED_MEM_CONT = 0x00 // Erased memory conten t eMMC EXT_CSD BOOT_CONFIG = 0x00 // Boot configuration eMMC EXT_CSD BOOT_BUS_WIDTH = 0x00 // Boot bus width1 eMMC EXT_CSD ERASE_GROUP_DEF = 0x00 // High-density erase g roup definition EMMC eMMC DRIVER INIT COMPLETE » Downloading complete » Elapsed time: 0:01.965 (24820 bytes/s) » End loading driver » Downloading |
07-19-2012, 20:55 | #82 (permalink) | ||
No Life Poster Join Date: Aug 2003 Location: Mars Age: 40
Member: 38084 Status: Offline Thanks Meter: 115 | i have i9100g bad flashed, now dead, i used omapflash but it still not go in download mode Quote:
07-19-2012, 22:27 | #83 (permalink) |
Member: 1787065 Status: Offline Thanks Meter: 0 | I got the drivers to install on a computer with windows 8 32 bits,( no luck with 64 bits) when the driver installation was done , i got a message saying the device may not work, and indeed on device manager shows up with a yellow exclamation symbol but at least its recognized it says"omap flash driver" or "locosto usb drive or " Omap 4460" it shows the name of any driver i choose to install but with a yellow sign , by the way is the nexus's screen supposed to turn on when i plug it to the usb? because it doesnt it just stays off and when i run the omap.bat it keeps saying waiting for the device. This is the error screen after i install the drivers and this is how the drivers appear on device manager |
07-20-2012, 22:39 | #84 (permalink) |
Freak Poster Join Date: Jan 2009 Location: Germany/NRW
Member: 936229 Status: Offline Sonork: 1606911 Thanks Meter: 115 | @LEENO Hi. I had same problem with dead i9100G,after resurection with Omapflash Tool no Download Mode,only Samsung Logo,after reset Device again dead. I have successfull repair with this Guide: Start Omap Tool and connect the i9100G without Battery,after successfull write SBL.bin Code: » Downloading 'Targets\Projects\espresso\Sbl.bin' » Sending data (1310720 bytes) :::::::::::::::::::: [1310720] » Downloading complete » Elapsed time: 0:00.906 (1446710 bytes/s) » cold_sw_reset » Elapsed time: 0:11.500 Premere un tasto per continuare . . . |
07-21-2012, 02:08 | #85 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Quote: Please install correct driver from "usb_drv_windows" Folder .. or maybe You need remove old driver first,Then reboot pc,,,and install correct driver |
07-21-2012, 17:14 | #86 (permalink) |
Insane Poster Join Date: Feb 2011
Member: 1517645 Status: Offline Thanks Meter: 9 | How do you use this to fix dead phone? My phone i9250 doesn't go into download mode or recovery it's just plain blank screen. I tried to plugin without battery via usb but program still doesnt pick up device. Thanks. |
07-22-2012, 00:04 | #89 (permalink) |
Member: 1786134 Status: Offline Thanks Meter: 0 | IMEI Repair I have I9250 with corrupt imei, just shows generic 00499... I am willing to solder on the JTAG pins but this box does not yet have IMEI repair feature via resurrection dll for I9250. How else can I repair IMEI? |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
I am looking for information about GSM-CABLES.NE | DUPOND | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 08-03-1999 15:29 |
Selling original Nokia DAU9P cable | TheDon | Main Sales Section | 0 | 07-21-1999 15:44 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
